AC power
Postby tdthinker » Wed Aug 11, 2004 10:11 pm
Some camping/rv stores can help you figure out a plan for all your needs, just call around.
Ryan
tdthinker
Postby denverd0n » Thu Aug 12, 2004 10:56 am
When it comes to buying solar panels my advice is to stick with one of the recognized brand names--like BP, Shell, Kyocera, Solarex, Unisolar--and beyond that buy the panel that gives the best price/watt. Among the major maufacturers there does not seem to be any significant difference in quality and none seem to over-rate the output of their panels.
denverd0n
Postby beverlyt » Thu Aug 12, 2004 3:07 pm
Jimbo,
No, I don't think we could run our 12v lights off the small 3amp power supply. I have no idea how many amps it would take.
I just bring it along to run an extra item.. my rig is a qrp rig so it will run with very low power.
Bev
beverlyt
Images: 20
Postby JamesW » Thu Aug 12, 2004 6:45 pm
Unless you are using LEDs some incandescent bulbs run upwards of 1.2 Amps each!
JamesW
Postby mikeschn » Fri Aug 13, 2004 3:04 pm
denverd0n wrote:When it comes to buying solar panels my advice is to stick with one of the recognized brand names--like BP, Shell, Kyocera, Solarex, Unisolar--and beyond that buy the panel that gives the best price/watt. Among the major maufacturers there does not seem to be any significant difference in quality and none seem to over-rate the output of their panels.
Do you recoginze this one? I can't find the mfg on it...
http://www.batterymart.com/battery.mv?p=ACC-10011
Postby denverd0n » Fri Aug 13, 2004 3:54 pm
"Do you recoginze this one? I can't find the mfg on it..."
I've seen those before. They're pretty expensive. $300 for 30 watts. By comparison, here's a link to panel from a well-known manufacturer that puts out twice the wattage for less money.
http://www.solar-electric.com/kc-60.html
denverd0n
Postby mikeschn » Fri Aug 13, 2004 3:57 pm
Good price, but it won't fit on my roof... I have about 21" on either side of the roof vent...
Postby campadk » Fri Aug 13, 2004 4:51 pm
RC wrote:KC8JWA de KE6BGN. Nice to see other hams up here. CUL......73 de RC......KE6BGN 8)
Back when I was in my younger years, I was VE3JHG. Can I get my call sign back?? My specialty was low power (milliwatts) morse. Does anyone still use morse code?? :?
campadk
Teardrop fun specialist
Images: 34
Postby JamesW » Fri Aug 13, 2004 5:13 pm
If your call has not been reissued to someone else, you may be able to get it back. Morse is still popular but I do not remember any of it. I am an Extra. By the way, I also used to work for ICOM. I left this past April.
JamesW
