papmom35 wrote:I've had a chance to really start getting to know her. I know that the fridge has got to go but my friend and I tried to slide it out of it's cubby hole but we couldn't do it. It appears there's some sort of plate on the bottom of the fridge that is getting caught on the "lip" of the cubby. I'm going to have to remove the trim around the cubby, the vent trim and then hopefully can tip it forward enough to get the plate over the lip. Once I do get it out, I plan to replace it with a much smaller fridge and was thinking of installing a shelf over it to maybe put a small AC unit on? Could I put a drip pan under the AC unit to catch the water or does there have to be a hose routed to the outside? Also, do I have to vent these room AC units?
The outlet over the sink area and the light on the side of overhead cabinet and facing the bench don't work. Please let it be a fuse problem!!
I probably won't be using the holding tank and wonder if it can be removed? The tubing is not hooked up to the sink anyway-at some point it was cut.
My brother says I can get a harness kit for the tow lights and just replace what is there and has been cut under the trailer rather than trying to splice it back together.
It needs a very good cleaning on the outside. Not sure what I should use for that job-just soap and water or a special cleaner?
I'm pretty sure it needs a total redo on the sealing of all seams on the outside. That will be fun!!
Wheel hubs (?) or whatever that part of the wheel is called needs a thorough cleaning, rust removal and repainting as do the tongue and the part of the chassis that forms a lip that the trailer sits in.
There are a lot of trim parts missing. Worth replacing with aluminum trim?
I need to find a new door window unit. The glass is cracked in multiple places and the hinge mechanism that allows the jolousie type windows to open and close is totally broken and I don't think its fixable? where would i find such a replacement unit?
There are 2 major holes/slits in the aluminum siding. Not sure how to repair this.
Looking at the vent from the roof it looks like it has pulled away from the roof on one side. Not sure I can reach it from a ladder-maybe but will the roof hold my weight?
Will I be able to install a shelf at the foot of the bench to hold a DVD player? Are there studs somewhere on these things?
That's it for now! Can't wait to get started cleaning her up next weekend!!
