I've had nothing but problems with plywood
Re: I've had nothing but problems with plywood
Postby 48Rob » Sun Apr 08, 2012 11:13 am
Seaboard as an alternative to plywood?
http://worldpanel.com/seaboard.htm
48Rob
Postby Wobbly Wheels » Sun Apr 08, 2012 12:11 pm
Rob, I've used a tone of that stuff on boats (though called SeaTeak or StarBoard). It will certainly be weatherproof and is inherently waterproof, but...
It's virtually impossible to glue it and, like the comments on using plastic decking, its strength/weight ratio is dismal.
It's great for things like fish tables and stair treads, but it's generally screwed onto an existing frame or substrate.
If you could overcome that, it would be a great material for a build. It's good for counters except that it's not heat resistant...but you can use your counter as a cutting board, then hit it with the any cleaner/disinfectant you want. I plan to use a piece of 3/4 I have to make a drop-in cutting board for over the sink.
If you used a single piece of 1/4" for the roof on a tear, you would still need internal bracing to keep it from sagging, but if it sagged and water pooled, it wouldn't cause problems unless there was a screw hole there.
Polysulfide sealants are about the only thing that (sort of) sticks to it, the primer and adhesive made specifically for it work about as well but they're an extra step. Both need to be backed up by mechanical fasteners.
On the plus side, it would be absolutely zero maintenance and pulling it through the car wash would have it looking brand new again. The black doesn't show scuffs and scratches much, the white doesn't at all.
But it's all JMHO of course.
Here's a bus panel for a battery bank that I made out of it:
The box is screwed together and I used it here because I wanted a nonconductive alternative to wood or glass.
Personally I would have made a mold and used fiberglass, but the company I was working for advertises that there's no fiberglass used anywhere on their (metal) boats. It takes a screw about as well as hardwood, but needs to be predrilled.
Wobbly Wheels
Postby 48Rob » Sun Apr 08, 2012 6:07 pm
Brian,
Thanks for the review! :thumbsup:
I found it while browsing for a composite flooring material and thought it may be of interest to those in this thread that were seeking a "waterproof" building material.
Rob
48Rob
