IraRat wrote:I was WONDERING why you didn't answer that one.
But that's not going to work for your interior roof.
Why not? Is it to thin?
IraRat wrote:Did you think regular finished paneling is going to make those bends you have without cracking? That's why I've been going nuts looking for the right stuff, and wound up ordering bendable birch ply from BOSTON to be shipped to FLORIDA!
I think just about any finished paneling is going to crack with that curve. You can do straight luan, don't know which thickness, but this is a major issue with the interior roof skin.
IraRat wrote:It's funny how depending on where you live, certain materials aren't available.
I think Bruce did a lot of kerfing on his too. It's great solution but I know I would wind up screwing it up. I'm cheap too, but I had to bite the bullet and spend the money on the bending birch. Once finished, I know it's going to look great too. (Well, as great as my skills will allow.)
My main point is that conventional wall paneling won't bend like that, and I would think it's way too thin to kerf. The interior ceiling is a BIG part of the structutral integrity, and even if you could kerf it well, I don't think you would want to kerf into such thin material.
Woody wrote:How come everyone has trouble bending radiuses, I bent 1/4" bead board birch paneling for the interior roof skin lengthwise on a 20" interior radius and halfway down the front with no problems at all. It just took time and some effort and it can be done. The same for the front exterior double radius skins using 1/4" luan also. It just takes alittle patience, some beer, some time and some more beer. Why spend all the money on expensive wood, use the savings for cool stuff for the teardrop.
Larwyn wrote:Woody,
Glad you posted that. My plan for this weekend is to try bending 1/4" luan around the front curve of the Escape Pod. The patience and time are not much of a problem. As for the beer, will Guinness Stout work as well or should I use one of the more pale American brews...???![]()
WoodSmith wrote:Larwyn wrote:Woody,
I prefer hard cider to beer, never developed a taste for it. So if it were me I'd pour the beer into my wallpaper steamer and use it to steam the plywood while drinking a cider. The steamer has an 8x10 or so - um - thingy to disperse the steam a little bit so you can get a larger area.
I recently made a cradle boat and used the wallpaper steamer to steam/wet the 1/4 inch oak ply for the sides - they bent MUCH easier after that. I was going to use the "pour boiling water on blankets/towels on top of the plywood" method that I've read about here, but saw the steamer in the shop and thought I'd try it.
One word of caution, the wood can get hot - don't use that old worn out pair of gloves with a hole in the finger when handling it (Don't ask me how I know this.)
