Rhino Ray wrote:What a great concept. If you had some traditional Tear Drop designs and a way to connect them to a platform on a frame that would take a ton of the guess work out of doing the basic build design. The hard part is the galley hatch so if you had a way of providing the hatch frame itself and the frame work around the hatch with hinges and locking mechanism that would be the ultimate in accomplishment. The rest of the construction should be easy. The molds could have inner and outer skin recesses so that insulation could be in between, a place to mount fenders and perhaps a frame for the door. These could be sold as inexpensive kits with most of the materials purchase locally. Modern building concepts and the traditional design, the possibilities are endless!![]()
Rhino Ray wrote:Now that's what we are talking about. Where can I get one?![]()
Rhino Ray wrote:Obviously you know the toughest part is the galley hatch, insuring that it is water tight.
Rhino Ray wrote:The roof can be one sheet of aluminum that will almost reach from the galley hinge to the front of the teardrop depending on the size. I used diamond plate on the front to make up the difference and it looks cool.
With your design the edge seams can be sealed quite nicely as long as there is enough lip to attach to, if using aluminum sides and roof they can be riveted like airplane skin with flat or flush rivets. A lot to think about
jscherb wrote:I wish there were one or two people within a reasonable distance from me that would like to build TrailTops using prototype parts. I could mold up the necessary sets of parts for people, and together we could work through assembling their prototypes. Unfortunately I'm pretty far from the rest of the world in my corner of the NY Finger Lakes reqion. I'm going to make up a proof-of-concept top for the Jeep-tub trailer that's sitting in my workshop right now, but it would be nice to do a couple of others as well.
Jeff
mgb4tim wrote:I'm guessing Pittsburgh isn't a reasonable distance? (I do a little fiberglass, too - http://www.morspeedperformance.com/)
cantsitstill wrote:Elmira!? You're close to me. For fiberglass parts, you might check out Empire Fiberglass in Little Falls. They might make your parts for you once you get your prototypes.
