Is the high price of oil, and ultimately, gas a permanent thing as the auto manufacturers seem to think? I've seen some posts that say part of it is due to inflation, and the other part of it is due to speculation.
Since I've never seen negative inflation, I'll assume for the moment, that portion of the cost is permanent. If that's true, then when we are ready to buy our next car, fuel economy will still be a factor in our choice.
So with that in mind I've started compiling the 5 year cost of some interesting vehicles. Not that I'd actually be interested in some of them, for example, I don't think I'd ever buy an Aveo.
This spreadsheet does not reflect any towing, because every situation is different.
This spreadsheet figures the cost to drive 20,000 miles per year, at the current prices of $4.15 for unleaded and $4.89 for diesel. The total reflects only the cost of the car plus the cost of fuel. (No maintenance, etc)
Aveo $12170 Max tow(unbraked): ? lbs, 27/37 annual fuel: $1824, 5 year total: $21290
Ford Fiesta (UK) $17700 Max tow(unbraked): 1650 lbs, 50/61.9 annual fuel: $1208, 5 year total: $23740
Cobalt XFE $15070 Max tow(unbraked): 1000 lbs, 27/36 annual fuel: $1844, 5 year total: $24290
Ford Focus $14395 Max tow(unbraked): ? lbs, 24/35 annual fuel: $2000, 5 year total: $24395
Matrix/Vibe $16190 Max tow(unbraked): 1500 lbs, 26/32 annual fuel: $1976, 5 year total: $26070
Corolla $17550 Max tow(unbraked): 1102 lbs, 26/35 annual fuel: $1908, 5 year total: $27090
Scion XB $15650 Max tow(unbraked): not rec'd lbs, 22/28 annual fuel: $2305, 5 year total: $27175
Prius $21500 Max tow(unbraked): 1000 lbs, 48/45 annual fuel: $1177, 5 year total: $27385
Ranger 2wd 4cyl auto $14330 Max tow(unbraked): 1000 lbs, 19/24 annual fuel: $2677, 5 year total: $27715
HHR $16730 Max tow(unbraked): ? lbs, 22/30 annual fuel: $2243, 5 year total: $27945
Tacoma 2wd 4cyl auto $14965 Max tow(unbraked): ? lbs, 19/25 annual fuel: $2634, 5 year total: $28135
PT Cruiser $15955 Max tow(unbraked): ? lbs, 21/26 annual fuel: $2441, 5 year total: $28160
Camry 4cyl $18570 Max tow(unbraked): 1000 lbs, 21/31 annual fuel: $2273, 5 year total: $29935
Jetta TDI $23000 Max tow(unbraked): 1560 lbs, 30/43 annual fuel: $1899, 5 year total: $32495
Silverado 2wd 6cyl auto $18515 Max tow(unbraked): ? lbs, 15/20 annual fuel: $3320, 5 year total: $35115
Fusion Hybrid $28000 Max tow(unbraked): 1000 lbs, 33/34 annual fuel: $1660, 5 year total: $36300
Fusion $25000 Max tow(unbraked): 1000 lbs, 20/28 annual fuel: $2441, 5 year total: $37205
Forester $25000 Max tow(unbraked): 2400 lbs, 20/26 annual fuel: $2515, 5 year total: $37575
Forester Diesel $28000 Max tow(unbraked): 2400 lbs, 26/33.8 annual fuel: $2279, 5 year total: $39395
Honda Odyssey $25860 Max tow(unbraked): ? lbs, 16/23 annual fuel: $3018, 5 year total: $40950
Volt $40000 Max tow(unbraked): ? lbs, 150/150 annual fuel: $368, 5 year total: $41840
Have any other vehicles you'd like to see on the spreadsheet? Let me know, and I'll add it.
P.S. What is the tow capacity of an Aveo? What is the European towing capacity of a Jetta?
P.P.S. Certain numbers had to be estimated since real number don't yet exist. If you are aware of any real numbers, like the cost of the Fusion Hybrid, for example, please let me know.
