by Wimperdink » Fri Apr 15, 2011 10:08 pm
what size and what kind of trailer? If its a teardrop, mine just had cushion and you picked one up and leaned it against the front. Easy and done. My TTT is actually up off the floor and the frame slides into itself. It goes from 81"L x 47"w while open, and when slid closed as a couch its 30". I would need 2 mattresses 7" or 8" thick, one of which is 30" wide and the other 17" wide to convert from couch to bed without gaps in either position.
You know a man is on the level if his bubble is in the middle.
