Clever woodburning stove
Postby Treeview » Tue Dec 13, 2011 9:45 am
A firebox and chimney built into one unit!
It looks like this might eliminate the need to bring along a saw and wedges.
http://deadwoodstove.com/
Treeview
Images: 30
Postby gregp136 » Tue Dec 13, 2011 9:57 am
I like it
Greg(ahd Laurie)
gregp136
Images: 100
Postby Treeview » Tue Dec 13, 2011 10:51 am
Yes...remember...R&D does NOT mean Research and Development. It really means Rip-Off and Destroy :lol:
I'd make it with three legs and maybe just a little more leg splay. The legs would be short enough to slip down the chimney for storage.
Keep the leg socket ends under the 'dripline' of the top would keep it compact.
here's a refinement...since the wind is NEVER blowing in the right direction the unit could easily be mounted on a swivel base. Then, the draft is better and the smoke is going away.
There is some sort of 'badge of honor' earned from cooking with the smoke blowing in your face though!
Now I'm going to start looking for scrap materials to make one!
Treeview
Images: 30
Postby GPW » Tue Dec 13, 2011 11:07 am
Just another overpriced Rocket stove ... http://solarcooking.wikia.com/wiki/Rocket_stove
Postby graybear13 » Tue Dec 13, 2011 11:08 am
That thing is known as a "Rocket Stove" and they work really well, that is the rocket stoves. Don't know about the deadwood.
graybear13
Postby schaney » Tue Dec 13, 2011 11:29 am
Interesting but pricey, I've been keeping on eye on BioLite, they are builting in heat generate electricity :thinking:
Scott
Camping the "Compact Way"
schaney
Images: 262
Postby droid_ca » Tue Dec 13, 2011 11:50 am
those are some pretty good stoves I like the idea of battery charging would be a good way to extend a camping trip by recharging the batteries
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Treeview » Tue Dec 13, 2011 12:09 pm
Wow! The BioLite sounds great!
I wonder about durability and life span.
That would solve the issue of trying to find a Currant Bush for recharging :lol:
Treeview
Images: 30
Postby Kathy53 » Tue Dec 13, 2011 12:56 pm
I bought this stove about 8 yrs ago for 24.95. Now 29.95. It is small but works half way decent. If it is to hot for a large campfire it's great for marshmellows. I have cooked chicken kabobs, steaks, hot dogs and hamburgers on it. Just a smaller version of a charcoal starter. Geared more for backpacking but I use it car camping. Can use twigs, charcoal, and alcohol. (Which you can buy an adapter for.)
http://www.trailstove.com/
Kathy53
Images: 60
Postby Woodbutcher » Tue Dec 13, 2011 8:09 pm
It's on sale for 143.00 now.
Woodbutcher
Postby Treeview » Tue Dec 13, 2011 8:59 pm
I'm not a farmer...an arborist...but I can handle metal cutting and welding as easy as I can a chainsaw and rope.
The idea and fabricating is easy. Marketing and selling is the key!
Treeview
Images: 30
Postby Wolffarmer » Tue Dec 13, 2011 11:52 pm
That Deadwood stove is missing one thing of a real rocket stove. A real on is insulated. Unless there is a smaller pipe inside the upright right one for and airspace between the two. I didn't bother to watch the video to see if I missed it. I have seen to many videos of rocket stoves already. And I just wanted to jump to conclusions.
8) .
Randy
Wolffarmer
Images: 309
off grid modern stove
Postby PcHistorian » Wed Dec 14, 2011 9:41 am
if you really want to go off grid, but be modern and green...
http://www.biolitestove.com/BioLite.html
(rocket stove with a thermocouple for phone charging.)
but the voltage must be about 5 VDC for USB. I want the 12VDC model. :-)
Elf Cottage
Build Documentary
https://sites.google.com/site/pchistorian/home/hobby/camping/elf-build
Build Forum
http://www.tnttt.com/viewtopic.php?t=48462
Build Album
http://www.tnttt.com/gallery/album.php?album_id=42
progress is progress. (don't look a gift "progress" in the mouth.)
PcHistorian
Images: 198
Postby Deryk the Pirate » Wed Dec 14, 2011 11:17 am
Interesting, I was looking into purchasing one of these for the spring. I like this one, http://www.stockstorage.com/heavy_duty_ ... stove.html
because you can use charcoal as well for long lower temp cooktimes. I did see another one with doors that you can close to lessen the draft so lower temps longer burntimes.
So many decisions out there lol
Deryk the Pirate
Images: 158
Postby Wolffarmer » Wed Dec 14, 2011 2:50 pm
That Grover stove is not to much more than the "non" rocket stove. The Grover will probably burn cleaner.
Weigh more, take up more room.
Randy
Wolffarmer
Images: 309
Users browsing this forum: Google [Bot] and 2 guests
