Thanks
Sparksalot wrote:I used the friction fit version from Hubcap Mikes on my wheels. They look and work great.
LDK wrote:Sparksalot wrote:I used the friction fit version from Hubcap Mikes on my wheels. They look and work great.
Did you use it on harbor freight wheels?? The problem with mine is the bearing hub sticks out almost 2 3/4". My hubcaps are about 9 1/4" dia. and have a 1" shoulder before it starts the curve. It just barely clears the bearing hub. I'm just gonna have to make some homemade hubcap clips to solve this problem. The question is, what to make them out of??
parnold wrote:Larry:
Hub cap clips are usually spring steel. At highway speeds, I would be real nervous about aluminum clips.
