mikeschn wrote:Has anyone tried building with western red cedar?
My thought is to build the sidewalls from western red cedar, and let the spars be western red cedar too. Then cover both with aluminum. That way, even though each screw hole is a possible entry point for water, the cedar will resist...
The only plywood would be the floor... and I suppose even that could be cedar.
I'd like to build a Winter Warrior that doesn't delaminate. Any thoughts?
mikeschn wrote:That IPE decking looks really good. It would be worth it... $2.09 ln ft. Yes, it's pricey, but if it never needs replacing, it's worth it.
jonw wrote:Isn't that pretty heavy? I had some on a deck a few years ago and at least I thought it was...
Martiangod wrote:Cedar will still rot, especially white.
It is just more resistant to rot then fir.
Pine is as good IMO
Could do a tongue and groove red cedar floor make sure you end seal
Now state side I know its more prevelant then here but can you not get composit studding, ripps just like wood, use the same tools and fasteners
Where you are going to fasten aluminum, you could run butyl tape on the corners and studs before hanging the aluminum
halfdome, Danny wrote:mikeschn wrote:That IPE decking looks really good. It would be worth it... $2.09 ln ft. Yes, it's pricey, but if it never needs replacing, it's worth it.
Ipe is sometimes difficult to find. An alternate wood is Goncalo Alves or commonly known as Tiger Wood.
I did a deck in Goncalo Alves in the Seattle area about 8-10 years ago.
It's so strong you only need it in 3/4" for the deck surface but the joists need to be 16" O/C.
It's specific gravity is .95 so it's quite heavy like Ipe which has a specific gravity of 1.08.
A specific gravity of 1.00, the wood will sink in water.
I had to fix a toilet there a couple months ago so I inspected it & it's just as solid as the day I built it.
Western Red Cedar has a SG of .37.
The plastic & sawdust decking is very heavy and pooches/crumbles where fasteners are used.
I have it for my deck & fence cap since the Cedar rotted away.
Personally, I wouldn't use it for anything else.
I still think for the money and light weightness Poplar (SG of .45) is the best choice for trailer framing & spars.
My source of wood information is from my book "World Woods In Color" by William A. Lincoln.Danny
mikeschn wrote:Michigan is just as wet as NY, so I hear what you are saying. Also, my trailers have to live outside all year long.
I may have to get a sunbrella cover made for my next teardrop, but meanwhile I am trying to stack the odds in my favor.
WRC is light and moisture resistant. So is aluminum. And I can keep the water out...![]()
But tell me. How moisture resistant is WRC. What if I drive in a screw that doesn't seal properly, and the water gets under the screw head, under the aluminum, and drips down the inside between the aluminum and the WRC? When does that become a problem?
Danny,
have they ever used Popular on boats? Just wondering...
it's perishable and liable to insect attack.
The sapwood which is a large portion of the tree is permeable for preservative treatment.
