LED LIghts
LED LIghts
Postby Rolly » Sat Apr 07, 2012 1:39 pm
I just picked up a couple of these at my local store. They make lumens. They have a plastic hook and a magnet on the back. I have seen much discussion about wiring lights, these would be simpler.
http://www.harborfreight.com/27-led-por ... 67227.html
Down periscope
Gary
Rolly
Re: LED LIghts
Postby eamarquardt » Sat Apr 07, 2012 3:57 pm
I went to the store to look at them but didn't see em where the clerk said they would be. So, I picked up some diamond hones and some of the little flat batteries. While checking out another clerk pointed them out on one of the "specials" racks. The clerk gave gave me a 25% off coupon good for "one item" tomorrow. He "hinted" that one could use it for multiple items. He also said that if I went back with the receipt for today's purchase they could refund the 25%.
Although a lot of stuff at HF is suspect, if you pick and choose you can get some OK stuff for a good price.
Gus
eamarquardt
Images: 150
Re: LED LIghts
Postby Shadow Catcher » Sat Apr 07, 2012 5:02 pm
I picked up two of them, the only problem is that they use three AAA batteries and from my experience with other HF LED lights( Which seem to favor AAa) that means a fairly short life. I do use Lithium batteries and we do take the Maha charger with us.
Re: LED LIghts
Postby working on it » Sat Apr 07, 2012 5:21 pm
I bought a couple of those at Tractor Supply in Oct.-Nov. timeframe. I gave one away that same day, and I've been using mine sporadically ever since. Reallly comes in handy. I haven't had to change the batteries yet either.
173193172890148599
working on it
Images: 457
Re: LED LIghts
Postby JonahPryor » Thu Apr 19, 2012 4:05 am
Shadow Catcher wrote:I picked up two of them, the only problem is that they use three AAA batteries and from my experience with other HF LED lights( Which seem to favor AAa) that means a fairly short life. I do use Lithium batteries and we do take the Maha charger with us.
waterproof led spot
12vdc dimmer
inline led dimmer
Yes, AAA batteries and led is a match, but the battery is easy to be used over..... The more troublesome! :thumbsup:
JonahPryor
