Crazy Idea I had
Crazy Idea I had
Postby Aaron Coffee » Sat Jun 16, 2012 10:58 pm
This is a crazy idea I had, build a teardrop on a t-bucket frame. Haven't decided which way I would do it, make the drivers compartment inside the teardrop (teardrop starting at cowl) or the teardrop starting behind the seats, the driver sitting in the open similar to old limosuines. It would have to be powered by something as unique as the rest of it, possibly a slant 6 dodge with a 3 speed overdrive manual tranny. Pretty much a lottery dream. Has anyone built or seen something similar?
Aaron
Aaron Coffee
Images: 26
Re: Crazy Idea I had
Postby Treeview » Sun Jun 17, 2012 12:11 am
If you're replicating a Ford, why not keep it Ford?
The slant six was a dependable engine but sure is ugly...I had one in my first car, a '64 Dodge w/push button.
Treeview
Images: 30
Postby Martiangod » Sun Jun 17, 2012 6:11 am
2.9 from a 86 - 90 ranger, cool looking efi v6
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby High Desert » Sun Jun 17, 2012 10:34 am
This pic was posted in another thread. So you're thinking of a teardrop kind of version of this Aaron? :thinking:
how about a flathead V8? :twisted:
Shaun
High Desert
Images: 27
Postby Aaron Coffee » Sun Jun 17, 2012 11:36 am
Yep, kind of a street rod version of that with a terdrop on the back. Just a thought I've had. Let's see I have three small block Chryslers in the garage (273, 318, and a bored and stroked 340), a 355 Chevy, a 440 Chrysler in the motorhome, enough parts to build a couple Dodge 2.2s. If I did ever build it, I would use a powertrain to get good economy over brute horsepower. A Ford straight six is a thought, we did borrow a Ford pickup with a straight six to haul the racecar once and it seemed to have more power than the 350 chevy pickup we borrowed. I have heard people that have thought of building a teardrop on the back of a older pickup, hmm that's another thought.
Aaron Coffee
Images: 26
Postby Vedette » Sun Jun 17, 2012 1:31 pm
Hi Aaron
Don't shut your brain off! Think outside of the Box!
But, do realize what you are biting off.
I just updated my album.
Click on it to see what I mean..........There are 90 or so pictures of my dream.
They show up backwards so you should start on page 7 and work your way to date.
Good Luck
& Good Roads
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Wolffarmer » Mon Jun 18, 2012 1:00 am
What! No VW Beetle in it also?
Randy
Wolffarmer
Images: 309
Postby bobhenry » Mon Jun 18, 2012 8:13 am
Winning lottery ticket pipe dream # 789.....
This body with a small cylinder diesel utility engine to power an electric generator for electric rear single wheel drive. Dual wheel front steer.
Ironically I have a pickup truck lumber rack that is shaped somewhat similar when inverted. It might make a good starting point for the frame and sidewall structure.
Postby Aaron Coffee » Mon Jun 18, 2012 5:31 pm
Just a lottey dream. I do know a guy that built a c-cab from scratch, so if I ever did build it, I would pick his brain. Just thinking about it, the one area that has me stumped is how I would do the rear kick up that is used on most t-buckets, it would eat into the teardrop space. Thinking just a sleeping cab, no galley. I would of course pull a teardrop with it, or a motorcycle trailer, that would fix my problem of not being able to take my motorcycle camping. I would want the teardrop integrated in the t-bucket body somehow, so it simply didn't look like a t-bucket with an extended frame with a teardrop on it. Guess I will have to play around with pencil and paper and learn how to play with pictures, and buy a lottery ticket.
Aaron
Aaron Coffee
Images: 26
Postby Corwin C » Wed Jun 20, 2012 8:06 pm
Something like this?
Maybe paint it a bright color and get rid of the feathered urns so it doesn't look like a hearse...
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby Wolffarmer » Wed Jun 20, 2012 8:29 pm
Ok, just what we all want. Grandpa Munster driving up to a gathering.
8)
Randy
Wolffarmer
Images: 309
Postby rainjer17 » Wed Jun 20, 2012 11:17 pm
How about front wheel drive in order to get the tear down to a comfortable height for easy access? Maybe an older Toronado or Caddy fwd chassis or possibly a Dodge Caravan. Just thinking out loud, but the possibilities seem endless depending how talented you are! :thinking:
rainjer17
Postby Treeview » Wed Jun 20, 2012 11:20 pm
Treeview
Images: 30
Postby eddie6775 » Thu Jun 21, 2012 6:33 pm
I like your idea. Now if it were mine, I'd go as modern as possible. You'll get more efficiency, and won't have to hunt for parts. 8) It's not as hard as most people think to adapt a computerized engine to and old chassis. Just a thought.
Of course, there would be an awful lot of wiring and that might not be your thing.
Maybe a casual stroll around the junk yard to see what's readily available still?
eddie6775
