CarlLaFong wrote:TJinPgh wrote: I'd probably consult a notary just to be sure.
Not to discredit any notaries out there but the main thing a notary does is check ID. There seems to be a misconception that they are the final say so in any sort of verification. Every eBay auction seems to contain a "Notarized Letter of Authenticity" proving that this is, indeed, Babe Ruth's actual cigar buttl. Just ain't so.
Maybe that's true in CA. Can't say. Here in PA? Notaries need to be up on every law dealing with titling and registration. If they're not and they submit something that's wrong they get their license yanked.
Which is why AAA tends to be a big PITA when it comes to these types of things. They dot every I and cross every T. Sometimes beyond what is necessary.
Yes, some notaries will certify anything. They don't last very long.
The REPUTABLE ones know the law and, in my experience, tend to be a reliable source of info.
To get back to the subject, tampering with, removing, switching or altering VINs is a Federal offense. That is the letter of the law.
Yes, but the question is whether or not any of those actually apply. If the frame were broken and he were taking the tongue or the tag from the registered trailer and sticking it on the new one then, yes, they would apply. He's not.
He's not remving it any more than one might be if they took the bolts out of the tongue and replaced them with new ones. Nor is he switching it for the same reason.
He's not altering the VIN. That suggests that he is altering numbers, which he is not.
The spirit of the law is to prevent renumbering of stolen vehicles or other fraudulent behaviors. I wouldn't worry if it was my trailer. Nobody is ever going to investigate you or impound your trailer unless you do a sloppy job or pull some sort of boneheaded stunt, and then it is still unlikely.
Agreed.
Like I said, if I were concerned about it, I'd contact a notary and ask them if, in their non-binding opinion, the tag can be switched. If they say no, then chances are one could simply contact the DMV where it was registered. Explain the situation to them and they will either tell him to switch the tag or they will issue a duplicate tag and tell him to send the non-registered tag to them.
