Finally got my Weekender weighed
Postby LWW » Wed Aug 08, 2012 9:18 pm
I finally had it weighed and with a regular twin matteress and a 4" foam on top of that it weighed in at 1160 lbs. I still don't have a real galley in it yet, just a solid oak table top for sitting at while camping. So far I haven't missed the galley so no hurry putting one in yet. I built mine 5' wide and 9 1/2' long on top of an old shortened boat trailer. I was worried it was too heavy for my Jeep Wrangler to pull it even thought the jeep has a 1500 lb towing capacity. It seems to pull it fine so far.
Has anyone else finished a weekender and checked your weight.Larry
LWW
Re: Finally got my Weekender weighed
Postby WhitneyK » Thu Aug 09, 2012 7:24 am
Larry,
Mine came in at 1260#, a little heavier than I had planned, but I feel it's solid. 1160's not bad, my dimentions are the exact same as your's and using an old trailer frame. Our Equinox owners manual says you can pull up to 1000 lbs in OD, Rats! just missed it. I'll be looking into a tranny cooler just to keep that expensive thing safe. My galley isn't elaborate, just funtional for our needs, so I don't think it really added that much weight. With your galley installed, cooler of ice, food, etc., you'll probably be coming in around the same weight as mine. My tongue jack has a wheel on it so it's easy to push around.
Hey, you're not that far away, may run into you some day.....
92422
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Postby wincrasher » Thu Aug 09, 2012 7:40 am
1000 lbs tow limit seems awfully low. I would think going over just a bit will be OK. A tranny cooler is probably overkill considering the weights you are talking about.
You may be able to ditch some weight. I got rid of my microwave and went with a toaster oven - saved 30 lbs! My last trip I carried home alot of stuff I never used - so I'm clearing those items out.
2015 Little Guy T@G Max
Follow my blog: http://www.wincrasher.blogspot.com
wincrasher
Images: 88
Postby WhitneyK » Thu Aug 09, 2012 11:18 am
wincrasher wrote:1000 lbs tow limit seems awfully low. I would think going over just a bit will be OK. A tranny cooler is probably overkill considering the weights you are talking about.
The tranny cooler is just an option. It has a 5 spd a/t, the 1000 lb limit is just for pulling in O/D, I figure if it's good & flat o/d is fine, get into some grades drop it down to L4. L4 isn't but about 300 rpm differnce so it shouldn't hurt the milage much.
wincrasher wrote:You may be able to ditch some weight. My last trip I carried home alot of stuff I never used - so I'm clearing those items out.
I agree with you there as well. I told my wife that we don't need to leave home with 3 wks worth of grub for a 2 week trip. They have grocery stores along the way, just buy 2 or 3 days worth at a time. When it's close to gone, get some more. We usually bring back a lot. Last trip to the Southwest we survived 2 wks on PB&J & pickled bolagna. We were about a day from home when we incountered a semi-homeless guy hitch hikin' with a sign that read "Hungry". We stopped and loaded him up with bottled water, soda, pudding, vienna sausage, beenie weenie's, chips, spoons, etc. tickled him & us to death. :D We only eat about once a day when we're on the road. Cup of coffee & little debbie for b-fast, pack of crackers for dinner, and try to eat a good supper. (I know, that's not good for ya) :frightened:
Now that we have a li'l camper, may have to change our eating habits, at least we have a MW now. mmmmm warm food mmmmmmm :FNP
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
Postby wincrasher » Thu Aug 09, 2012 11:23 am
Here is another idea - I got a thermoelectric cooler - it's about 1 cubic foot in size and weighs about 2 pounds. I'm trying it out on my next trip. If I can get by with the battery I have, then that will save a huge amount of weight - about 40lbs of a too big cooler and all the ice.
wincrasher
Images: 88
Postby asianflava » Thu Aug 09, 2012 1:07 pm
What size is it and how was it constructed? My 5x10 (not a weekender) came in at 1150, that's with a Queen size memory foam mattress, microwave, air conditioner, and battery.
asianflava
Postby WhitneyK » Thu Aug 09, 2012 1:27 pm
:thinking: Maybe if I fill my air mattress with HELIUM....... :thinking:
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
Postby NathanL » Thu Aug 09, 2012 1:38 pm
I would imagine if you used a boat trailer a pretty chunk is in the trailer itself.
NathanL
Postby Forrest747 » Thu Aug 09, 2012 2:24 pm
1600 pounds here tha i pull with my Jeep. Was shocked when i got the weight.
Forrest747
Cowbell Donating Member
Images: 447
Postby WhitneyK » Thu Aug 09, 2012 3:53 pm
Forrest747 wrote:1600 pounds here tha i pull with my Jeep. Was shocked when i got the weight.
I'm suprised it not heavier than that Forrest with the big jet sittin' on top of it. :lol:
96595
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
Postby Maureenm » Thu Aug 09, 2012 4:59 pm
Maybe the jets holding it up.... :thinking: :lol:
Couldn't resist.
Maureenm
Postby Forrest747 » Thu Aug 09, 2012 5:09 pm
You know you have weight issues when planes think they can land on you.
Forrest747
Images: 447
Postby LWW » Thu Aug 09, 2012 6:39 pm
1260 lbs makes me feel like I'm about right then. I've had it out a couple times, most of it in the flat lands on the Eastern Shore and didn't loose to much on the milage of the jeep. I used it to camp out in the hospital parking lot a couple of nights in Charlottesville couple months ago. Going up the hills on I64 had to drop back out of overdrive couple times, jeeps got a 5 speed. I've even slept in it in some really big thunder storms with lots of rain, no leaks. So I'm happy with it. Now if the gas prices will go down some I can make my way out west to see more of the sights.Larry
LWW
Users browsing this forum: Bing [Bot] and 11 guests
