Kody,
I'm not an engineer, or expert, but I do have an opinion...
Shocks work very well for some vehicles.
Not all vehicles need them.
If a vehicle rides/handles poorly because it does not have them, it has either been designed to carry a wide range of weights, or the builder didn't fit it with a proper suspension to fit the build.
To elaborate;
If a vehicle, say a car, has been designed to carry 4 passengers and cargo, the suspension must be able to carry 4 passengers and cargo just as comfortably as when there is no cargo and just one driver.
So, the suspension (springs) have to be able to handle both extremes.
They must be heavy duty enough to hold up the max. Weight, so the springs/suspension are much stiffer than they would be if the car were only ever to carry one person.
In this case, shocks are needed to keep the springs/suspension from bouncing up and down.
In the case of a teardrop or tiny trailer, if the builder calculates the finished weight and chooses a suspension setup that is neither too much, nor too little, the trailer will ride/handle very well without shocks.
If the builder blindly chooses whatever springs/suspension with little or no regard to the finished weight and needs of the trailer, shocks may be a necessary afterthought to correct an issue.
I don't mean this in a way that is derogatory to builders who have shocks, but rather am trying to explain how if you take the time to match your choice of components to the finished build, you may be able to avoid the need.
Most trailer parts companies offer a limited range of "weights" for trailer suspensions.
The red trailers are an example; they come with an axle and springs with a certain weight rating.
If you decide to build a trailer using one of these, you get what they give you.
Some spring sets can be adjusted by removing a leaf.
Some torsion springs can be ordered at a custom weight rating.
The point of this post is to offer an alternative.
You don't have to settle for a poor ride that requires the addition of shock absorbers if you know what the finished weight will be and choose components that all work together.
Rob
