Looking for homemade door profiles.
Postby BlackCatRacing » Sun Feb 03, 2013 8:40 pm
I have searched and found a few door profiles, but know there is more. I cut out of 3/4" plywood basically a 24"x36" door entrance. What is the best way to reuse these slabs as doors with a nice water tight seal? I already have a drip cap made.. Thanks for your help...
Patrick
"Far better it is to dare mighty things, to win glorious triumphs even though checkered by failure, than to rank with those poor spirits who neither enjoy nor suffer much because they live in the gray twilight that knows neither victory nor defeat."
Theodore Roosevelt...
BlackCatRacing
Re: Looking for homemade door profiles.
Postby Ron Dickey » Mon Feb 04, 2013 1:38 am
http://en.wikibooks.org/wiki/How_To_Bui ... iderations
here is a starting point
look in here
viewtopic.php?t=12276
I had to have some one show me how to make a door. once you do it is is not hard. Hanging the door is harder.
173882......173887
Ron Dickey
Images: 787
Postby BlackCatRacing » Mon Feb 04, 2013 9:24 am
Thank you Ron. Pondering the "House type door" with a jam..
BlackCatRacing
Postby aggie79 » Mon Feb 04, 2013 6:39 pm
This is how I did my doors:
The outer weather seal has worked so well that I haven't installed the inner seal yet.
I used a router and template to cut out the door openings. The cut-outs became the doors.
Postby grant whipp » Mon Feb 04, 2013 8:51 pm
What does your trailer profile look like, Patrick?
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby BlackCatRacing » Tue Feb 05, 2013 8:04 am
Aggie79 I like that profile and thank you for posting it.
Grant it is like this http://www.youtube.com/watch?v=CLHegP4VfDA but on a H/F trailer for now. I had the trailer and most of the material. I really like the look of a rounded teardrop but need space to haul two kayaks. I have taken a lot of pictures but shamefully am having trouble down sizing them to get them posted. I will figure it out soon.
BlackCatRacing
Postby grant whipp » Tue Feb 05, 2013 11:59 am
That's a pretty simple shape for the door, Patrick, so trimming it with T-Molding on the door and Edge Molding around the door opening will be quite easy. A lot of folks who have used my formed offset door hinges have said that they stiffen the wall a tremendous amount, but the other advantage is that they set the door outwards 1/8" so that it seals evenly all the way around.
Clearances should be 3/8" on the hinge side and 1/4" on the non-hinge sides. If you plan on going with the "suicide"-style door shown in the video, then you should run Drip Molding not only over the top of the door, but also all the way down in front of the door to minimize any water from being driven in while pulling in the rain.
How thick will your doors & walls ultimately be?
As always ...
CHEERS!
grant whipp
Images: 117
Postby BlackCatRacing » Wed Feb 06, 2013 8:28 am
About 1 1/4' to 1 1/2" inch if I insulate. I am intersted in the offset hindges and hardware.
BlackCatRacing
Postby grant whipp » Wed Feb 06, 2013 12:03 pm
Patrick!
I can't form my hinges for wall/door thicknesses of more than 1" ... but, it seems like you'll be framing with 3/4" timber? If that is the case, I can sell you an un-bent hinge and you can trim it to your wall/door thickness, and you can screw directly into the edge of the timber. Send me an e-mail at [email protected] and I will send you and e-mail with some drawings for reference. If you also include either a drawing of your door with dimensions, or just the dimensions of each straight line, I can work you up a quote for your needs.
Continued Good Luck, and as always ...
CHEERS!
grant whipp
Images: 117
