GerryS wrote:It sounds like a dumb question, but there is a ratio in nature that is common called "phi". --- roughly 1.618 :1 that relates to beauty that is common in art as well as architecture.
I can't help but wonder if "cute" trailer sizes share this same ratio....
A 10 foot long trailer would be roughly 6.18 foot tall for example....
An 8 long trailer would be roughly 4.94 foot all...etc
This seems about right in my head....
Woodbutcher wrote:Mike, I always work backwards. I figure out the length of the bed the gap space I need and then I move to the galley and figure out where everything should go. If I am putting in a cooler, which direction will it go. Add in any curves from the profile and then make a full size template, and draw everything in. You can see how it works and it's a good way to view the profile. This will give you the minimum size. You can always stretch it out if you need to. Just remember size is weight. If you don't need it don't make it bigger then it has to be.
