Slim(ish) bedding
Slim(ish) bedding
Postby OreoGaborio » Fri Jun 27, 2014 10:25 am
Hi all! First post here.
Looking for affordable recommendations for an affordable bedding solution for my 14x7.5 cargo trailer that'll be comfortable for my girlfriend an I.
Currently I'm using a queen sized air mattress on a collapsable cot platform type thing, but it's too big & uncomfortable... I want to get away from fragile air mattresses and air pumps.
I'm considering something like a 4" foam mattress topper on a plywood platform that I can mount on a piano hinge to fold up against the wall, but I question whether or not a foam mattress topper will be firm enough?
:thinking:
Reason for thinking about foam is I will order it in a full size, then trim a few inches off the side to fit in the amount of wall room I have (50" wide vs typical 54" for a full size mattress)
Any recommendations?
OreoGaborio
Re: Slim(ish) bedding
Postby mallymal » Fri Jun 27, 2014 12:48 pm
What about a futon? That would give you a bed and a sofa in one easy package, and I'm guessing you would have more space and headroom for that than in a small teAr...
Another variation is that many vw campers have something called a rock and roll bed, again it switches from sofa to bed, but is fixed to a frame. You can certainly get kits here in the uk, sure you can there... :thumbsup:
mallymal
Images: 18
Postby OreoGaborio » Fri Jun 27, 2014 1:01 pm
Thought about it, but I'm using this trailer primariy to haul two motorcycles... get to the track, bikes come out, bed goes down. 8)
Bed's gotta fold flat against the wall (sideways), thus looking for something 3-4" thick, but firm enough to be comfortable. Are mattress toppers firm enough to be used by themselves or are they like lying on marshmallows?
OreoGaborio
Postby eggsalad » Fri Jun 27, 2014 2:51 pm
I found my 4" foam twin at a mattress store. Look for those flyers in the mail that promise $50 mattresses. Bit of a bait-and-switch if you want a REAL bed, but perfect for a camper.
I think I really shocked the sales guy buy actually buying it! :)
eggsalad
Postby nevadatear » Fri Jun 27, 2014 3:06 pm
We used a foam one from walmart. It is a 6". I cut it to fit. It was @$150 i think.
nevadatear
Images: 171
Postby rowerwet » Fri Jun 27, 2014 3:49 pm
to avoid bottoming out see if you can find a spring type mattress support instead of a flat sheet of plywood. Look at the support for a murphy bed, it is all springs around the edges like a trampoline, with metal links to support the mattress.
It makes a kind of flat box spring for a thinner mattress.
rowerwet
Images: 521
Postby tony.latham » Fri Jun 27, 2014 4:27 pm
We've got 5" of foam from the Foam Factory topped with 2" of memory foam. It's as good as our bed. :thumbsup:
Postby PaulS » Fri Jun 27, 2014 5:33 pm
After trying many different ones I am now using a 6inch memory foam brand spa sensensations from Walmart. It has partial foam and memory foam. And the wife and I are very happy. When we had the 4 inch we ended up putting those foam interlocking mats under it. We cut ours down with a filet knife and it cut like butter
PaulS
PaulS
Postby bc toys » Sat Jun 28, 2014 10:42 am
we have the full size memory foam from wally world and love it we have it at home also you might think about turning it cross ways takes up less trailer floor space and you can store stuff under it out of the way
bc toys
Images: 42
Postby Shadow Catcher » Sun Jun 29, 2014 7:25 am
We have a Foam Factory queen size and got the 5", 4" would have been fine!
Postby OreoGaborio » Mon Jun 30, 2014 4:25 pm
Shadow Catcher wrote:We have a Foam Factory queen size and got the 5", 4" would have been fine!
Good... 4" is as thick as I'm willing to go.
EDIT: This what you went with? http://www.thefoamfactory.com/mattress/ ... ional.html
OreoGaborio
Postby OreoGaborio » Mon Jun 30, 2014 5:19 pm
Hmmmm... I could do 2" of their Lux High Quality Foam with 2" of their top of the line memory foam combined to make a full size mattress, plus cover for 206 shipped... :thinking:
OreoGaborio
