pigcooker wrote:3/4" - 1" thick rigid, under the mattress, surely
won't impede too much. Just an inexpensive
cure, which takes little time to do. If you
disagree, that's OK. Have a Happy New Year.
Doug
Nobody wrote:There probably as many answers to your question as there are builders on this forum. None are 'wrong' or incorrect. What's right for one person may not work as well for another.
I built my TD in 2006, using an HF 1800# trailer & a couple of profile drawings I expanded from quarter inch graph paper. I built my floor from ripped spruce 2x4's, 1x6 pine for side rails, & 1/2" CDX ply for the decking. After the 'floor' was completed I inverted it on a couple of sawhorses & 'painted' it with asphalt roofing compound. Contrary to conventional wisdom, the coating wasn't nearly as 'stinky' as expected, & the 'tackiness' only lasted as long as it took to dry (overnight). I then cut pieces of 1" styrofoam (Dow 'blueboard') to fit the recesses under the floor, installed them with PL Adhesive, & as an extra caution, I used small pieces of scrap wood as 'battens', 'nailed' to the floor frame with 18ga brads from my HF nailer/stapler. Almost 8yrs & 20K plus miles later (towed thru all kinds of terrain from freeway to National Forest/BLM back country roads/trails) the foam shows considerable stains/marks of travel, a few tiny 'gouges' probably from road debris, but NO deterioration or tendency to 'de-laminate' from the floor. In SE New Mexico in 2010 we encountered standing water in the streets of several towns, that in places almost 'floated' the TD. I've also driven through lots of heavy rain/T'Storms where I'm sure the tires & passing vehicles sprayed lots of water up under the TD. I've found no indication of residual moisture nor any evidence of rot in the wood portion of the floor, nor corrosion to the metal of the trailer chassis. As an aside, I live in central Arkansas where our average humidity is quite high & equipment not properly protected has ample opportunity to suffer ill effects from it...
Here's a few pix of my floor under construction
This how the underside looks this morning (not bad considering what it's been exposed to since 9/2006)
felixx wrote:Hi there
Thanks guys, thats saved a job!
Dez - Nice to see another south islander here.
Did I know you in Wanganui?
