Hi there
I am wondering, do I nearly need to insulate my floors?
I will be camping in New Zealand, rarely below -5 deg C and rarely above 30 deg C
I will have a 17mm ply floor with carpet and a 6" foam matteress.
Will I need an inch of foam laminated between 2 sheets of ply or is that overkill?
(I will have 17mm thick foam in the walls laminated between 1/4" ply (inside) and Laminated aluclad on the outside)
(nsulation in the roof will be one inch)
Cheers
Felixx
