Meaure once cut Twice.......
Postby JamesW » Sat Aug 07, 2004 11:29 pm
Just kidding! I have the side profiles cut out and sanded. Tomorrow I will be cutting out the doors. I am a little nervous about this... Is it better to use a Skill saw with a plunge cut then switch to a Jigsaw or should I try to borrow a plunge router :? Anyway, if I am successful with the doors I should be able to get the sides mounted and supported.
JamesW
Postby Guest » Sat Aug 07, 2004 11:32 pm
James,
Go with the router. You'll get a much better result.
Guest
Postby Chip » Sun Aug 08, 2004 6:31 am
Ahhh a man after my own way,,,,the cut twice program has worked out for me in my building,,look on the bright side ,,it does give you a lot more new design possibilities,,,but I lost a lot of hair scratching my head wondering how in the hairy I am gonna make this thing fit and work,,
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby mikeschn » Sun Aug 08, 2004 6:50 am
I used a circular saw on the doors, and a jig saw on the rounded corners. It works, but a router with a template would work far better. Go to Steve Fredricks page for cutting with a router...
http://www.steve-frederick.com/body1
Postby tdthinker » Mon Aug 09, 2004 12:23 am
One thing my dad has branded into my minde is measure twice cut once! I am 15 and work with wood like it is worth its wheight in gold. I dont like to mess up. I would use the router. bye
Ryan
tdthinker
Postby JamesW » Mon Aug 09, 2004 12:37 am
My 5 x 10 sheets of plywood was $112 each! It is GOLD! I am from IL to. Where are you from?
JamesW
Postby tdthinker » Mon Aug 09, 2004 12:41 am
I am from centrale illinois. A small town of 4400 called Auburn. And where in the world did you finde 5x10 plywood?????? I could only finde 4x10 and at the cost of $200 a sheet. If you could tell me where you got that it would be soooooo apreciated. I would like to see your tear and give you a hand if you need it. bye
Ryan
tdthinker
Postby JamesW » Mon Aug 09, 2004 12:45 am
I am in Everett, Washington. I ordered it through a company called Midway Plywood. In Mukilteo, WA. They ordered it from Portland! I am originally from Taylorville! I was born in Springfield.
JamesW
Postby tdthinker » Mon Aug 09, 2004 12:57 am
I have been to taylorville many times, we baught another mansion there to restore after its burning but on my homecoming night we had a bad storm that caught are first mansion on fire. Sad to say we had to drop the taylorville mansion to redo are first. Do you remember a large brick mansion on I-55 going tords Carlinville? That is ares. bye
Ryan
tdthinker
Postby tdthinker » Thu Aug 12, 2004 1:05 pm
James, do they have a web site I can order from? I was going to do the tear 4 feet high but 5 is MUCH better, it will be easier to get in and out of and a nicer height to sit in the dinette. Thanks a million, bye!!!
Ryan
tdthinker
Postby JamesW » Thu Aug 12, 2004 6:48 pm
[quote="tdthinker"]James, do they have a web site I can order from? I was going to do the tear 4 feet high but 5 is MUCH better, it will be easier to get in and out of and a nicer height to sit in the dinette. Thanks a million, bye!!![/quote]
No website but here is the link to the yahoo yellow pages.
http://yp.yahoo.com/py/ypMap.py?Pyt=Typ ... gT:1:fbT:0
JamesW
Postby tdthinker » Fri Aug 13, 2004 11:09 pm
thanks
Ryan
tdthinker
Postby JamesW » Fri Aug 13, 2004 11:13 pm
I do remember the brick mansion. It has been a few years since I have been "home". I will let you know when I plan on going back. maybe we could meet face to face. You may have your trailer done by then...
JamesW
