I'm in need of replacing my jack. What's a good manufacturer of high end swivel jacks? thanks.
Scott
Fulton Trailer Jack - F1413050334
Maintenance-free, corrosion-resistant jack is made for marine, recreational and utility trailers. Features aluminum alloy construction, adjustable mount and swivel system and wide-track wheels for superior stability.
Features:
Adjustable mount and swivel system for easy lifting and transport
Can be adjusted to any height for mounting
Swivels into position simply with the integrated, easy-to-grip pull pin
Maintenance-free construction
Sealed and lubricated, one-piece gearbox eliminates the need for manual lubrication
Anodized finish on inner and outer aluminum alloy tubes prevents rust even in the harshest environment
Wide wheel base allows for increased stability
Sidewind handle is made of strong plastic for durability and ease of use
Optional wheel wedge eliminates the need for a chock
Weld-on installation
Specs:
Application: fits 3" x 5" tongues
Lift height: 10"
Bracket range of adjustability: 8"
Wheel diameter: 8"
Pull pin diameter: 9/16"
Mounting bolt pattern: 3-1/2" x 4-1/2" on center
Capacity: 1,600 lbs
Lifetime limited warranty
