where to carry a battery
Postby PKCSPT » Sun Sep 06, 2015 5:40 pm
I want to get a battery to run my fan overnight, real simple set up. Can I safely carry it in my car til I get to my campsite and set it up when I get there. I don't want to add any more weight to my hitch, I already have a box I put there with my tent and now I will have added some from my canoe with my one man canoe loader. Hesitate to put it inside my camper for transport where it might get bounced around, it would have sit on my mattress. With my car and gear the front passenger side floor is where I have the most room. I pull with a beetle, space is tight.
121172 116946 159644
PKCSPT
Images: 61
Re: where to carry a battery
Postby lrrowe » Sun Sep 06, 2015 9:42 pm
I personally cannot come with a reason why you could not carry it in your vehicle. I would think you would keep it in a container such as a plastic marine battery box. This way you keep the dirty and acid stuff away from your other stuff. But depending on the size battery you get, it could be heavy to lift in and out of the car.
Bob
lrrowe
Images: 439
Postby darrellbeck » Sun Sep 06, 2015 10:07 pm
I will second Bob's reply. The battery box would only add about a pound to the battery weight. Worth way more than its cost just as an insurance measure.
Darrell
darrellbeck
Images: 24
Postby Dale M. » Mon Sep 07, 2015 6:59 am
If you put it in galley area (behind axle) you will counter balance some of the weight you are putting on tongue/hitch from added weight on tongue... Of course it will depend on battery size /weight and how you intend to charge it....
Might find better answer in electrical section....
Dale
Dale M.
Images: 18
Postby PKCSPT » Mon Sep 07, 2015 8:17 am
Dale if it goes inside the tear it sits on my mattress, I only have a shelf for a galley. But I had not thought of getting a battery box, great tip and I will do that. Thanks everyone!
PKCSPT
Images: 61
Postby Vedette » Mon Sep 07, 2015 10:33 am
I took the Battery out of Miss Piggy yesterday (first time since I put it in April 2013) and remembered how heavy a DC27 really is.
I am so glad it is behind the wheels and not on the tongue. :worship: Because a Dale said, that counter weight as opposed to the dead weight on the tongue, really will affect your tongue weight.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby tony.latham » Mon Sep 07, 2015 11:00 am
I'd recommend you put it in your trunk, if you've got room. Today's vehicles are incredibly crashworthy, but imagine being in a rollover with a fifty pound hunk of lead bouncing around inside.
I think a Group 24 is about the smallest marine battery they make. I think they've got about 40 useable amps, so a Fantastic Fan would run for fifteen or twenty hours before you'd begin to damage it.
Postby PKCSPT » Mon Sep 07, 2015 4:27 pm
There is a thought. I don't plan on rolling my car, but should that happen a 100lb dog rolling around is bad enough. Since I take my grandkids I really have to think this through a bit more
PKCSPT
Images: 61
Postby dales133 » Mon Sep 07, 2015 4:33 pm
Ive got a realy small agem thats about 15 ah but lasts a suprisingly long time .
Iits about the with of 2 packets of smoke and the hight of one and about 6 inches long.
Completly sealed and safe to use inside.
Might work for you.
The added bonus is they use them in servers and alarms
and replace them every year so the can be picked up cheap
dales133
Postby Vedette » Mon Sep 07, 2015 4:49 pm
Sorry Dale
I didn't understand a word you said??? :? Must be your accent??? :lol:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby PKCSPT » Mon Sep 07, 2015 5:02 pm
Dale, where do they sell used ones? Might be an idea to pick up one, try it and if I like it could go with a new one. I was planning on going to a battery plus or fleet farm.
PKCSPT
Images: 61
Postby dales133 » Mon Sep 07, 2015 5:06 pm
Check out govt or big corperation auctions.
Call the it department of places that run big servers or alarm companies,fire and burglar.
You can get them at fea markets ect too.
New they are about 25 here,used but as new they are around 5.
I use them for my boat electronics and i get days. I take 2 or 3 with me if i go away
dales133
Postby buckisland1950 » Mon Sep 07, 2015 6:29 pm
You might check into a motorcycle battery or lawn tractor battery. Either should be able to power your fan just not sure how long.....
buckisland1950
Postby martymcfly » Mon Sep 07, 2015 6:53 pm
If you don't need a lot of battery, because the reply above this one is suggesting a motorcycle battery, how about getting a jump box? It would be clean, not take up a bunch of space, and you could use it to jump start your car if needed, and it is easy to recharge.
martymcfly
Postby darrellbeck » Mon Sep 07, 2015 8:45 pm
It sounds like the battery that Dale is referring to is one of the pair that go in GoGo handicap scooters, You can find a bunch of different amp ones on EBay. They have a mat construction and they are sealed so they won't leak in any position, I just bought some of the higher amp ones, and the price was around $32 apiece, freight included.
Darrell
darrellbeck
Images: 24
