Dexter axel
Dexter axel
Postby Shadow Catcher » Wed Oct 21, 2015 8:20 pm
According to Dexter you can not upgrade 7" to 10" brakes, is there a way, short of a new axle.
Re: Dexter axel
Postby Vedette » Thu Oct 22, 2015 10:38 am
How much more braking power do you need for a Teardrop.
7 inch brake should be more than anyone would need.
Under 1500 lbs should not require any brakes if you Tow Vehicle is sufficient. :thinking:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Dexter axel
Postby Shadow Catcher » Thu Oct 22, 2015 12:36 pm
I am over 1800# loaded and while the car is certified for more I was not particularly comfortable at times in the mountains on the down hill. The real uncomfortable was coming down Tioga pass to Lee Vining about a 4,000 foot drop in 12 miles, brakes on the car were smoking and I used a lower gear part of the time and the brakes and rotors were new at the beginning of the trip.
A poster concerning his trip to Alaska made the comment he wanted to upgrade to 10" and he had one fail. Going is optional, I am a bit paranoid about stopping.
Re: Dexter axel
Postby tony.latham » Thu Oct 22, 2015 12:43 pm
Shadow Catcher wrote:I am over 1800# loaded and while the car is certified for more I was not particularly comfortable at times in the mountains on the down hill. The real uncomfortable was coming down Tioga pass to Lee Vining about a 4,000 foot drop in 12 miles, brakes on the car were smoking and I used a lower gear part of the time and the brakes and rotors were new at the beginning of the trip.
Does your Dexter have the brake mounting flanges? Is it an idler axle?
Re: Dexter axel
Postby Shadow Catcher » Thu Oct 22, 2015 12:59 pm
It is the torsion axle and has the 7" brakes which do work, sort of.
Re: Dexter axel
Postby aggie79 » Thu Oct 22, 2015 2:43 pm
Do you know which series of Dexter that you have - #9, #10, etc.?
Most likely, based upon the weight, your teardrop has Dexter Torflex #9. I don't believe these can take 10" brakes because the shoes and drums are wider than those for 7" brakes.
Re: Dexter axel
Postby Shadow Catcher » Thu Oct 22, 2015 3:21 pm
I frankly don't know which one it is, is there a way to tell?
Re: Dexter axel
Postby Esteban » Thu Oct 22, 2015 4:18 pm
Shadow Catcher maybe this will help you find which Dexter Torflex axle you have. The Dexter Trailer_Axle_Resources/Torflex_Information.pdf show that the Torflex #9 axle has a 2.38" square bar. The Torflex #10 has a larger 2.5" square bar.
:thinking: So, yes, you may need to replace your axle in order to have 10" brakes IF you find you now have a Dexter #9 Torflex axle.
:thinking: If you havea Dexter #9 axle and it is worth it to you to buy a new axle in order to have more robust 10" brakes you might consider getting a heavy duty Timbren axle-less axle which has a better suspension for off road use. Or upgrade to a Dexter Torflex #10. Or buy a customized 3500# flexiride axle with a derated load capacity to suit your needs.
Or learn to live with your (current?) Dexter #9 axle and its 7" brakes AND get better (high temperature tolerant) brake shoes on your tow vehicle? If I remember right you have a Subaru Outback. If so you might get help from the subaruoutback.org forum about how to improve your Outback's brakes.
Steve - SLO, CA
Esteban
Images: 15
Re: Dexter axel
Postby Shadow Catcher » Thu Oct 22, 2015 7:16 pm
Thanks Steve
I will crawl under tomorrow with the calipers. While I might like the Timbren the frame is aluminum and with out a lot of reinforcement. If I have to make a change I will probably go with a Flexride.
