Vedette thinks this is a cool idea
Postby byrdz1 » Sat Dec 05, 2015 8:31 pm
Posted for Brian AKA Vedette
https://k30.kn3.net/7/3/5/C/3/A/743.gif
Just Remember, no matter where you go... there you are
byrdz1
Images: 40
Re: Vedette thinks this is a cool idea
Postby KennethW » Sat Dec 05, 2015 9:19 pm
Neat, Would be fairly easy to seal I think :thinking:
KennethW
Images: 82
Postby WizardOfOdds » Sat Dec 05, 2015 11:13 pm
I like it. I find 3 things worth noting: It looks to me that
1- If you skin the outside of the door frame, notice that the outside surface is on the outside in both the opened and closed positions. With a regular hinged door the outside surface when closed ends up facing the building when opened.
2- It appears the (single) door must be twice as tall as it is wide. So if you have a pair of doors (it appears there is a matching door that opens in the opposite direction), then the overall door opening is a square. Further, the top and bottom sections of a single door must be squares and the triangular sections of them are equilateral (45-45-90 degrees). That should make them relatively easy and economical to construct.
3- The connections between the door and the building is only at two points (top & bottom) and it looks to me that they pivot only in the vertical plane. Again, a perhaps unexpected simplicity.
WizardOfOdds: Chalet shaped rag roof clam shell TIER drop for 4 cylinder tow
Tip Top Tier Drop thread http://www.tnttt.com/viewtopic.php?f=5&t=56232
Unusual Designs thread http://www.tnttt.com/viewtopic.php?f=5&t=64495
Tale of 2 Trailers thread http://www.tnttt.com/viewtopic.php?f=35&t=61451
WizardOfOdds
Images: 43
Postby Vedette » Sun Dec 06, 2015 1:40 am
Thanks Marianne
I just don't have the computer skills to share some of the cool stuff I come across Sandi actually found this). :cry:
Anyway it is far to cool and could work for many applications. But I thought the coolest part, was that it would clear things top and bottom that might otherwise be in the way.
ie. a light fixture in front of the door or a uphill grade that might be in front of the door.
This would allow you to have a cupboard door that could swing open over a counter top with an object on it???? :thumbsup:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
