Trailer level
Trailer level
Postby rossamerson » Sun Jan 03, 2016 1:54 pm
Is the angle at which my trailer sitting ok? Or do I need to find a way to lower the hitch?
138602
rossamerson
Re: Trailer level
Postby KennethW » Sun Jan 03, 2016 2:10 pm
If you ever want to tow anything of more weight you will want to put on a receiver hitch. Most bumpers are not very strong. With a receiver hitch you can do a drop hitch. If you never plan to tow anything of any weight you can use a bolt on receiver tube.
KennethW
Images: 82
Re: Trailer level
Postby les45 » Sun Jan 03, 2016 2:14 pm
+1 on what KennethW said. With a frame mounted hitch, you can buy a receiver with different drop lengths to match your level trailer height.
les45
Images: 605
Re: Trailer level
Postby rossamerson » Sun Jan 03, 2016 2:22 pm
Can I tow a TD as it is now if I keep the the weight below 1000lbs?
rossamerson
Re: Trailer level
Postby KennethW » Sun Jan 03, 2016 2:28 pm
Yes, You can but you will have to unhook to sleep and use the galley. With the hitch that high you might change the weight on the tongue that could led to a trailer that sways. :(
You can try it if it does not work we gave you a way to make it work good luck with your build. :thumbsup:
KennethW
Images: 82
Re: Trailer level
Postby Vedette » Sun Jan 03, 2016 3:27 pm
rossamerson wrote:Is the angle at which my trailer sitting ok? Or do I need to find a way to lower the hitch?
138602
The angle looks totally upside down to me?? :?
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Trailer level
Postby KennethW » Sun Jan 03, 2016 3:39 pm
It is weird that if you click on the picture it turns over.
KennethW
Images: 82
Re: Trailer level
Postby Vedette » Sun Jan 03, 2016 4:18 pm
KennethW wrote:It is weird that if you click on the picture it turns over.
Doesn't work that way for me???
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Trailer level
Postby les45 » Sun Jan 03, 2016 4:37 pm
Vedette wrote:Doesn't work that way for me???
Brian
right click on image, save to your pic file, and then rotate it
then you'll see that it's not level
les45
Images: 605
Re: Trailer level
Postby Jdw2717 » Sun Jan 03, 2016 5:04 pm
I put one of the Curt receiver hitches on the Toyota that I used to have. It was very easy and worked great. I was able to put the drop hitch in and have the camper run level. They also have a light kit that snaps in between the taillight connections that is very easy to install. I highly recommend that you go that route. It was only around $200 and will be much safer. When you turn using the bumper hitch like that you will put the trailer tongue in a bind and at the very least dent the bumper. Worst case you could break the tongue. Plus, with it riding level you won't have to unhitch the trailer to use it as stated above.
"Twenty years form now you will be more disappointed by the things that you didn't do than by the ones you did. So throw off the bowlines... Explore. Dream. Discover" Mark Twain
John & Tatanya
Jdw2717
Images: 34
Re: Trailer level
Postby halfdome, Danny » Sun Jan 03, 2016 6:08 pm
You'd have to be from "Down Under" to see it properly. :lol:
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Re: Trailer level
Postby dales133 » Sun Jan 03, 2016 6:12 pm
halfdome, Danny wrote:Image
:D Danny
Nope,upside down here too
dales133
Re: Trailer level
Postby lrrowe » Sun Jan 03, 2016 6:33 pm
It does flip over on my iPad.
Bob
lrrowe
Images: 439
Re: Trailer level
Postby tlsallada » Sun Jan 03, 2016 6:36 pm
It looks fine when I stand on my head although then all the printing is upside down and the blood is rushing to my head....... I can never win!!
tlsallada
Images: 10
Re: Trailer level
Postby rossamerson » Sun Jan 03, 2016 6:47 pm
It was right side up when I created the post. When i submitted the post, it inverted. When i click on the picture it has the proper orientation....no clue..
rossamerson
