Cosmo wrote:How many amps is the battery you want to charge?
How many amps can your controller handle?
Cosmo
Cosmo wrote:Lots of c good hoices available! Are the batteries switched? Meaning you use one at a time and switch from one to the other?
Like noseoil I am using a 100 watt/5 amp panel.
Its similar to this one http://www.amazon.com/dp/B017OMTAV6/ref ... 03PN&psc=1
My controller (which I love) is a Flexcharge PV7D which will change w batteries. posting.php?mode=reply&f=2&t=65290 The controller uses the PULSE CHARGING Algorithm which treats the battery very gently and works great. http://flexcharge.com/Charging-Algorithm-Explained.html
You can see both in action here
https://youtu.be/4KbTwLJc6XA
Good luck with your choice!
Cosmo
Cosmo wrote:Its up to you. There is no right or wrong. My question about switched was to understand. Some people like to wear down one battery then switch to the other so they know how far along they are on draining the battery.
I am still not sure how you have them hooked up. Maybe in parallel?
If that's the case you have a total of 70 amps available. Not sure how many amps a day your using. I use about 6 amps a day maximum on a 55amp hour battery, If you can estimate or measure how many amps your are drawing you will know better how much solar you need to refill.
vitya-velik wrote:Cosmo wrote:Its up to you. There is no right or wrong. My question about switched was to understand. Some people like to wear down one battery then switch to the other so they know how far along they are on draining the battery.
Would this be a good set up? I need to power 4-5 lights, fan, 12v fridge, and like a laptop or small tv. With 100w panel that charge controller and would i need 1 or 2 of my batteries? I think I will make my teardrop with just 12v set up. Do I need a high voltage panel/controller or will a low one work too? Thanks alot.
PKCSPT wrote:wonder how something like this would work. I too am looking at finally getting a battery and small solar panel for my tear.
http://www.amazon.com/Bushnell-PowerSync-SolarWrap-Mini-Charger/dp/B00L8IY7WA/ref=sr_1_9?ie=UTF8&qid=1454289496&sr=8-9&keywords=flexible+solar+panel
vitya-velik wrote:I need a solar panel kit for my teardrop. Has to be under $250 and just 1 panel that can produce the most watts. Length has to be under 48" anyone have any good reccomendations? I have 2- 12V 35mah universal batteries
Esteban wrote:vitya-velik wrote:I need a solar panel kit for my teardrop. Has to be under $250 and just 1 panel that can produce the most watts. Length has to be under 48" anyone have any good reccomendations? I have 2- 12V 35mah universal batteries
A 39.5" x 39" renogy-store.com/150W-12V-Mono-Solar-Panel might comfortably fit your needs. It's currently priced at $204.99 with free shipping to the Continental U.S.
vitya-velik wrote:Esteban wrote:vitya-velik wrote:I need a solar panel kit for my teardrop. Has to be under $250 and just 1 panel that can produce the most watts. Length has to be under 48" anyone have any good reccomendations? I have 2- 12V 35mah universal batteries
Is it just the panel or a kit? Sorry I can't tell.
