Solar panels
Solar panels
Postby vitya-velik » Sun Jan 31, 2016 2:41 pm
I need a solar panel kit for my teardrop. Has to be under $250 and just 1 panel that can produce the most watts. Length has to be under 48" anyone have any good reccomendations? I have 2- 12V 35mah universal batteries
vitya-velik
Re: Solar panels
Postby Cosmo » Sun Jan 31, 2016 4:30 pm
How many amps is the battery you want to charge?
How many amps can your controller handle?
Cosmo
FUN WITH TEARDROP TRAILER VIDEOS
https://www.youtube.com/CosmoWeems/videos
I am an Amazon Associate if you buy from my links I may profit at no cost to you!
Cosmo
Re: Solar panels
Postby noseoil » Sun Jan 31, 2016 5:23 pm
I use the Renogy 100 watt panel system from Amazon. It works.
137905
noseoil
Images: 670
Re: Solar panels
Postby vitya-velik » Sun Jan 31, 2016 6:32 pm
Cosmo wrote:How many amps is the battery you want to charge?
Cosmo
I need to buy a controller and theyre 35 amps each
vitya-velik
Re: Solar panels
Postby Cosmo » Sun Jan 31, 2016 6:56 pm
Lots of c good hoices available! Are the batteries switched? Meaning you use one at a time and switch from one to the other?
Like noseoil I am using a 100 watt/5 amp panel.
Its similar to this one http://www.amazon.com/dp/B017OMTAV6/ref ... 03PN&psc=1
My controller (which I love) is a Flexcharge PV7D which will change w batteries. posting.php?mode=reply&f=2&t=65290 The controller uses the PULSE CHARGING Algorithm which treats the battery very gently and works great. http://flexcharge.com/Charging-Algorithm-Explained.html
You can see both in action here
https://youtu.be/4KbTwLJc6XA
Good luck with your choice!
Cosmo
Cosmo
Re: Solar panels
Postby vitya-velik » Sun Jan 31, 2016 7:14 pm
Cosmo wrote:Lots of c good hoices available! Are the batteries switched? Meaning you use one at a time and switch from one to the other?
Cosmo
Thanks. Is having batteries swithced better? Is 100 watt panel enough for you or would you reccomend to get 150?
vitya-velik
Re: Solar panels
Postby Cosmo » Sun Jan 31, 2016 7:54 pm
Its up to you. There is no right or wrong. My question about switched was to understand. Some people like to wear down one battery then switch to the other so they know how far along they are on draining the battery.
I am still not sure how you have them hooked up. Maybe in parallel?
If that's the case you have a total of 70 amps available. Not sure how many amps a day your using. I use about 6 amps a day maximum on a 55amp hour battery, If you can estimate or measure how many amps your are drawing you will know better how much solar you need to refill.
Cosmo
Re: Solar panels
Postby Pleiades » Sun Jan 31, 2016 8:16 pm
I just seen a FLEXIBLE 100w panel on eBay for 180 or so. Got my eyes on it.
Better to bring it and not need it...that whole thing.
Pleiades
Re: Solar panels
Postby PKCSPT » Sun Jan 31, 2016 8:20 pm
wonder how something like this would work. I too am looking at finally getting a battery and small solar panel for my tear.
http://www.amazon.com/Bushnell-PowerSync-SolarWrap-Mini-Charger/dp/B00L8IY7WA/ref=sr_1_9?ie=UTF8&qid=1454289496&sr=8-9&keywords=flexible+solar+panel
121172 116946 159644
PKCSPT
Images: 61
Re: Solar panels
Postby vitya-velik » Sun Jan 31, 2016 8:40 pm
Cosmo wrote:Its up to you. There is no right or wrong. My question about switched was to understand. Some people like to wear down one battery then switch to the other so they know how far along they are on draining the battery.
Would this be a good set up? I need to power 4-5 lights, fan, 12v fridge, and like a laptop or small tv. With 100w panel that charge controller and would i need 1 or 2 of my batteries? I think I will make my teardrop with just 12v set up. Do I need a high voltage panel/controller or will a low one work too? Thanks alot.
vitya-velik
Re: Solar panels
Postby vitya-velik » Sun Jan 31, 2016 8:41 pm
http://m.ebay.com/itm/PV-SOLAR-KIT-100- ... 0408.m2460
vitya-velik
Re: Solar panels
Postby Pleiades » Sun Jan 31, 2016 8:46 pm
PKCSPT wrote:wonder how something like this would work. I too am looking at finally getting a battery and small solar panel for my tear.
I have this exact one works good
Pleiades
Re: Solar panels
Postby Esteban » Sun Jan 31, 2016 9:31 pm
vitya-velik wrote:I need a solar panel kit for my teardrop. Has to be under $250 and just 1 panel that can produce the most watts. Length has to be under 48" anyone have any good reccomendations? I have 2- 12V 35mah universal batteries
A 39.5" x 39" renogy-store.com/150W-12V-Mono-Solar-Panel might comfortably fit your needs. It's currently priced at $204.99 with free shipping to the Continental U.S.
Renogy also sells three different 100 watt panels with prices ranging from $139.99 to $219.99.
Steve - SLO, CA
Esteban
Images: 15
Re: Solar panels
Postby vitya-velik » Sun Jan 31, 2016 9:40 pm
Is it just the panel or a kit? Sorry I can't tell.
vitya-velik
Re: Solar panels
Postby Esteban » Sun Jan 31, 2016 9:50 pm
It's just a panel. You'd also need to buy a charge controller, wiring and solar panel mounts.
Steve - SLO, CA
Esteban
Images: 15
