let me see your television mounts.
Postby Trevor57 » Thu Mar 03, 2016 4:15 pm
I have tries searching for pics of people mounting tvs in their trailers. Unfortunately tv is too short of a search term. I would like pics, or input about how you have your tvs mounted.
Trevor57
Images: 24
Re: let me see your television mounts.
Postby Socal Tom » Thu Mar 03, 2016 4:37 pm
I use a mount similar to this ( though we took out the middle link so its closer to the rear wall.
http://www.amazon.com/Swift-Mount-SWIFT ... s=tv+mount
Socal Tom
Postby lrrowe » Thu Mar 03, 2016 4:41 pm
The posts on this subject that I recall seem to be very similar to Tom's. That is what I will consider for mine.
Bob
lrrowe
Images: 439
Postby Socal Tom » Thu Mar 03, 2016 4:56 pm
My only addition is that I'm considering changing how I use the TV. I'm either going to get rid of it all together, ( and just use an IPAd) ( we normally just watch TV when the weather is bad or for a few minutes before bed). Or change it so that I can set it outside and share with others. We often camp with other kids, so it might be nice to watch a movie together when the campfire isn't doing it.
Also, if you use a smaller TV, one of the swing up mounts could be nice.
Socal Tom
Postby MtnDon » Thu Mar 03, 2016 5:06 pm
We used a similar arm. Very nice with the swinging arm. I have a strap that secures it against the wall for travel. I used a small piece of carpet to cushion the edge that touches the wall when stored.
MtnDon
Images: 24
Postby halfdome, Danny » Thu Mar 03, 2016 8:07 pm
We simply lay the TV face down on the sleeping bag covered mattress while traveling, it stays put.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Greg M » Fri Mar 04, 2016 12:26 am
That's too simple Danny, we want a SOLUTION ;)
Greg M
*Geek Extraordinaire
Images: 85
Postby dales133 » Fri Mar 04, 2016 2:48 am
I purchased a tv bracket to mount it in the cabin but i see the merrits in using it in the galley or outside.
I see invention on the horrizen
dales133
Postby pete49 » Fri Mar 04, 2016 11:09 pm
I go camping to see the world outside. For wet weather I have books or my tablet if in service range. :lol:
TV...opiate for the masses
Pete
pete49
Postby Trevor57 » Fri Mar 04, 2016 11:28 pm
I think I have a pretty good idea what I will end up doing with my setup. Thank you for the good ideas, to those who offered something helpful.
Trevor57
Images: 24
Postby Jdw2717 » Sat Mar 05, 2016 9:46 am
I used a small fixed mount that I bought from monoprice.com. I have also purchased one from them for the house. They are great quality at around $30 or less. Check out their hdmi cables also. They are all I use for the camper and the house and they are less then $5 for 6 foot cables. Great stuff.
All that said, I have thought about taking the TV out of the camper (at least being permanently mounted to the wall) so we can have the space for more storage. I just don't use it enough when my wife and I both go camping and we could use the space.
"Twenty years form now you will be more disappointed by the things that you didn't do than by the ones you did. So throw off the bowlines... Explore. Dream. Discover" Mark Twain
John & Tatanya
Jdw2717
Images: 34
Postby bdosborn » Sat Mar 05, 2016 7:22 pm
I used on of these because it has dual locking pins. The list price is expensive but it goes on sale for a lot better price every now and then:
Linky
Images: 806
Postby captbobh2o2004 » Sun Mar 06, 2016 4:27 pm
Do you need to adjust the TV or will it be OK to mount it so folks can watch it laying down?.. We went for a nice flat screen and mounted it on the shelf by our feet (Along side my Ham Radio gear) It has worked great for the past 2 years. If this works for you, all I did was bolt the base to the shelf. Make sure you have everything plugged in that needs to be before you bolt it down. :thumbsup:
captbobh2o2004
Postby steve cowan » Sat Mar 12, 2016 1:53 pm
No antenna but watch DVD's before sleep.Was using a laptop but got a deal on TV/DVD player.
Mount rubber vibration isolators with t-nuts.
140048
140039
Bought a mount kit but was bulky so only used part of it and made some brackets from aluminum angle
140041
Plate mounted to TV.
140042
Bracket mounted.
140043
140045
All done.
140047
steve cowan
Images: 207
