AC Placement.
AC Placement.
Postby Hader » Mon Jul 04, 2016 11:03 am
Hello All,
Working on some plans to convert a CT for travel and camping. What do you all think about the attached plan for AC under the bed, and ventilation through the floor?
Hader
Images: 84
Re: AC Placement.
Postby GuitarPhotog » Mon Jul 04, 2016 11:24 am
The back half of the AC must be in the fresh air for it to function. You can do that with duct work and fans but a simple vent to the roof won't cut it.
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: AC Placement.
Postby Hader » Mon Jul 04, 2016 11:30 am
GuitarPhotog wrote:The back half of the AC must be in the fresh air for it to function. You can do that with duct work and fans but a simple vent to the roof won't cut it.
<Chas>
:beer:
Thank you GuitarPhotog,
The Vent is through the floor (24' x 18'), fresh air is coming up from under the trailer.
Hader
Images: 84
Re: AC Placement.
Postby DrewsBrews » Mon Jul 04, 2016 11:43 am
It may work fine for your space, but one issue I see with designs such as that is the hot air wants to rise..Path of least resistance would be for the warmed condenser exhaust air to be sucked back up the intake again potentially making the unit much less effective.
Maybe if you could put a hinged extension to the center divider (trap door style), then when you want to use the A/c unlatch it and let it hang down to provide a more of a barrier, increasing the likelyhood of the air finding it's way around the sides of the trailer instead. Though it seems more like a bandaid to an inferior design. Ducting the exhaust out the side/s of the trailer might be a superior option. Would probably work well if you offset the unit to one side and could just have a louvered panel on the side of the trailer to vent the exhaust air, but the intake could still pull cool air from underneath.
DrewsBrews
Re: AC Placement.
Postby Hader » Mon Jul 04, 2016 12:07 pm
[quote="DrewsBrews"] "Maybe if you could put a hinged extension to the center divider (trap door style), then when you want to use the A/c unlatch it and let it hang down to provide a more of a barrier"
Thanks DrewsBrews.
Great idea. I will add the hinged extension to the design.
Hader
Images: 84
Re: AC Placement.
Postby Hader » Sat Jul 16, 2016 12:37 pm
Hader
Images: 84
Re: AC Placement.
Postby Dusty Mark » Sat Jul 16, 2016 1:29 pm
If your AC unit is adjacent to one of the walls, you could get fresh air for the intake section through a marine inspection hatch installed in the exterior wall. That would separate the hot exhaust air from your fresh intake air. The hatches are waterproof.
This is the one I used in my build. It looks to be working quite well.
http://www.ebay.com/itm/Dusky-Boat-Access-Hatch-13-x-23-Large-Inspection-Deck-Hatch-Marine-Black-NEW-/262012575429?hash=item3d012a9ec5:g:q8kAAOSwjVVV1SCU&vxp=mtr
Dusty Mark
Images: 395
Re: AC Placement.
Postby Hader » Sat Jul 16, 2016 3:44 pm
Dusty Mark wrote:If your AC unit is adjacent to one of the walls, you could get fresh air for the intake section through a marine inspection hatch installed in the exterior wall. That would separate the hot exhaust air from your fresh intake air. The hatches are waterproof.
Thanks Dusty,
I'm going to try not cutting any walls other than for windows. Every thing will be through the floor including power, propane, water and powered vents. The trailer doesn't even have a rear door.
Hader
Images: 84
Users browsing this forum: Google [Bot] and 5 guests
