not a biggie: just an inexpensive pole clamp
Postby Bob Hammond » Sun Aug 14, 2016 12:07 pm
Hi, i saw these at stake clamps and thought they might be useful for tables, counters, lamps etc. They look reasonably sturdy, are lightweight, and the price is right.
http://www.menards.com/main/building-ma ... 1838240172
Curator
Museum of Unfinished Projects
Bob Hammond
Re: not a biggie: just an inexpensive pole clamp
Postby pohukai » Sun Aug 14, 2016 2:13 pm
I'm not sure exactly how they work... Look like maybe they could be used as stabilizers?
pohukai
Images: 9
Postby Bob Hammond » Sun Aug 14, 2016 2:57 pm
click on the second picture in the ad listing, and you'll see.
The yellow bracket is screwed to an object, e.g. a table apron or door. Then a pole, e.g. a 1" dowel, is dropped through to the desired distance and then the clamping screw is tightened so that the black pad presses on the dowel.
Curator
Bob Hammond
Postby KennethW » Sun Aug 14, 2016 2:58 pm
I will have to check them out I can see a lot of uses for them. Roof rack mounts?, solar panel mounts?, awning mounts? table mounts? use as hinges? Anything that uses a pipe to mount would be a use. COOL!!
KennethW
Images: 82
Postby KennethW » Tue Aug 16, 2016 8:33 pm
When to Menard and looked at the clamps. they are not the most solid clamps. But for mounting thing on a foamie I would definitely use them. A nice big glue down base.
KennethW
Images: 82
Postby Bob Hammond » Wed Aug 17, 2016 6:50 am
I don't think I'd use them for jackstands, but for propping up a table leaf or lamp, or a lot of other things that may need positioning adjustments, they're ok.
Curator
Bob Hammond
