Boone Tailgate Table Mounted To Side of Trailer
Postby DWT77 » Wed Aug 31, 2016 4:37 pm
Has anyone welded a hitch to the side of their trailer and attached a tailgate table? I was thinking it might be a quick/easy way to set up a table for the galley.
I was thinking it might be a little heavy and storage of the table might be a problem too. Any thoughts?
I did a quick search in the forums but didn't see it.
https://www.etrailer.com/Camping-and-Hi ... 70114.html
DWT77
Images: 473
Re: Boone Tailgate Table Mounted To Side of Trailer
Postby desertmoose » Wed Aug 31, 2016 8:06 pm
Several trailers have this.
I made my bumper removable.
I welded hitch tubes on the back of the frame
Then, when the bumper is removed, I can plug a side table in.
We love having the space. I put the support at an angle so we can close the hatch with the table in place.
Sam
desertmoose
Images: 98
Postby DWT77 » Wed Aug 31, 2016 8:41 pm
desertmoose wrote:Several trailers have this.
Sam
I like that. Especially the angle for the galley door. Thanks for the photos!
I was also thinking of putting a hitch in the front that way I could utilize the same concept. Possibly a quick set up/break down for a pole mounted solar panel or air conditioner unit.
DWT77
Images: 473
Postby Dale M. » Thu Sep 01, 2016 9:44 am
I used a piece of 1 inch ID square tubing as a receiver to mount home made bracket for table to side of trailer... Dont see why it would not work with standard receivers... You just need to be a little creative...
Dale
Dale M.
Images: 18
Postby drhill » Thu Sep 01, 2016 9:49 am
I went to the Shasta Lake gathering this year and saw a few tables mounted to receivers and decided to add a table. I had been using a 2' x 4' folding plastic table for additional galley space but I figured the receiver mounted type would be easier on uneven ground. I have a 2" receiver in the center of my trailer but using that would block the hatch of course. The rear frame cross member is 2x2 HSS. I had planned to use stabilizer jacks mounted in the ends of that tube and did a few times. I eventually went to using 2 scissor car jacks from the wreckers mounted on the underside of the trailer. Those work well and now that I have a table mounted off the trailer, I use the stabilizer jacks most of the time to avoid the table shaking with somebody moving inside the trailer.
The front end of the table had a 1.75 x 1.75 piece of birch that slid inside the 2x2 HSS for a tight fit and the back end of the table has a folding adjustable length leg. There is a shelf hanging below the table from nylon cloth at the ends of the shelf. It all folds up and I toss it on top of the bed for travel. On a 3 day stay with lots of rain, the birch swelled up inside the HSS and I had to saw it off. Later at home had to drill holes through the birch and let a heat gun blow air through it for a couple hours before I could hammer it out from the other end of the HSS. I had worried about swelling but never thought it would be that bad. Now I have a more loose fitting piece of birch with a tee nut and a hand knob with bolt to tighten it into place for use. It is off to the side so the hatch clears it. It makes a great L shaped galley that would easily rival the counter space in a big 5th wheel. I think Cooking in the outdoor galley is the best part of teardrop camping.
142406
ps- Sam, how do you make the pictures in the posts appear large enough to see them without having to click on them?
Don
drhill
Images: 37
