Thanks for the help this site gives.
Jerry
3GKnight wrote:Don't necessarily have a solution, mostly commiseration... I couldn't find any at 5 lumber stores nearby. I could by special order but it was astronomically expensive. I suggest researching this forum for methods to splice plywood. I used biscuits, which were fine but I would try something different next time, like a dovetail.
bobwhite215 wrote:What did you find lacking about the biscuits? That was my plan ~ biscuits, glue and pocket screws to hold it together.
clip wrote:Are you thinking about a sliding divetail or more of a puzzle piece?
clip wrote:I see, yours is more a curved finger joint I thought a true dovetail shape about 4 inches high 1 inch deep cut with a jig saw etc. where you had to lay both pieces flat glue up and press it down from the top like a puzzle piece would give glue surface and locking strength, but neither one solves the paint crack problem.
