eagle24 wrote:Do you attach your floor so it would be easy to remove the camper shell from the frame if necessary? I’m considering using 1/4” self tapping screws along the sides. They would be underneath the walls making it difficult to remove the shell from the frame. Bad idea?....
friz wrote:Mine is spaced from the trailer using carriage bolts and hockey pucks. I dont have to worry about moisture getting between the shell and the trailer frame.
Sent from my SM-G930V using Tapatalk
KTM_Guy wrote:I think bad idea. What if you get some damage that would be easier to repair by taking the camper off the trailer? You wouldn’t be able to easy.
Todd
Sparksalot wrote:KTM_Guy wrote:I think bad idea. What if you get some damage that would be easier to repair by taking the camper off the trailer? You wouldn’t be able to easy.
Todd
I always thought if the tear needed that kind of repair it had bigger issues.
I believe it is 6 oz E-glass. Very stretchy on the bias. It is amazing what you can get it to conform to.eagle24 wrote:friz wrote:Mine is spaced from the trailer using carriage bolts and hockey pucks. I dont have to worry about moisture getting between the shell and the trailer frame.
Friz,
Having built several boats, I gotta say you did an outstanding job on your trailer! Your epoxy work is very neat. I always get epoxy on EVERYTHING including the dog!Your build thread is very nice! I enjoyed reading through it and looking at the pics. What weight cloth did you use on the outside? It probably tells, but I missed it.
Greg
Ooooooo pretty.tony.latham wrote:Me? I fall into the camp that wants to keep the option open for removing the cabin. My concern isn't so much about the cabin itself but for a weld that needs to be fixed.
The other point I'll make is that it's much easier to build the cabin on a dolly or stand and then load it on the chassis when it's nearly done. (I've done it both ways.) It's a pain to build around the wheels and tongue.
[img][Imgur](https://i.imgur.com/CaYxb3Z.jpg)[/img]
If you look at Youtube videos on how the big boys do it––So-Cal or Camp-Inn or Vistabule or the others––none of them build on the chassis.
Just some thoughts...![]()
greygoos wrote:Elevator bolts were put into production for exactly that, elevators. They were used for grain elevators and were manufactured to snap with stress.
