Door dilemma
Door dilemma
Postby Simple_Abound » Wed Aug 14, 2024 7:58 pm
I thought my doors were crooked, that is not the case. After using every straightedge around I have discovered its not the doors but the door frame. Do I use the same technique to distort the door as you would to straighten it? It is 3/16", it wouldn't bother me except it's not completely sealed. I'm not afraid to ruin the inside of the door.
Thank you
Simple_Abound
Images: 139
Re: Door dilemma
Postby tony.latham » Wed Aug 14, 2024 8:19 pm
Simple_Abound wrote:I thought my doors were crooked, that is not the case. After using every straightedge around I have discovered its not the doors but the door frame. Do I use the same technique to distort the door as you would to straighten it? It is 3/16", it wouldn't bother me except it's not completely sealed. I'm not afraid to ruin the inside of the door.
Thank you
Photos would help.
Re: Door dilemma
Postby Simple_Abound » Wed Aug 14, 2024 9:21 pm
173891173890
After trying to climb through one door and out the other I discovered that if you lock the doors from the outside you can't unlock them from the inside. The door jambs are flush on the top and hinge side. They start to taper out after the handles and taper back in towards the hinge side. Just pushing the door in without locking the handle has the same result.When I cut and assembled the pieces I clamped them as mirror images. I must not have had them as flat as I thought.
Simple_Abound
Images: 139
Re: Door dilemma
Postby tony.latham » Wed Aug 14, 2024 9:54 pm
What are your walls made out of?
Re: Door dilemma
Postby Simple_Abound » Thu Aug 15, 2024 3:43 pm
tony.latham wrote:What are your walls made out of?
The walls are made of 3 layers. The exterior side is 1/4" acx, the middle is 3/4" and the interior is 1/8".
Simple_Abound
Images: 139
Re: Door dilemma
Postby tony.latham » Thu Aug 15, 2024 4:57 pm
Are you sure it's the walls that are tweaked?
Re: Door dilemma
Postby Simple_Abound » Fri Aug 16, 2024 7:42 pm
My 2 hour commute gave me some time to think, maybe it's my building process. After reading through the door section in your book, I realized my mistake. The shims for my door latches were 3/4" plywood not 1/2" and 1/8". While the bottoms aren't totally flush, it's a lot better than before. The first picture shows how much thickness was taken out by the rod sticking out. I'm dumbfounded how something so small can make a huge difference.
173899173898173897
Simple_Abound
Images: 139
Re: Door dilemma
Postby tony.latham » Fri Aug 16, 2024 10:24 pm
I'm just damn glad you figured it out.
