Cargo trailer jack failure. [emoji45]
Postby Modstock » Sun Sep 29, 2024 4:08 pm
While hooking up this morning my jack started getting hard to turn as usual.
I've lubed it recently and it'll usually clear it up.
As I was getting to the hard last 1/2" , it fell down . Luckily I was behind the jack and my feet were clear.
Pulled out the trucks scissor jack and got it back on the ball.
Wrapped a strap around just to keep it up incase while driving .
I think im under warranty still but don't want the same crap I have.
What are your suggestions to good dependable trailer jacks ?
Something with a grease zerk maybe.
Sent from my SM-A115AP using Tapatalk
Modstock
Re: Cargo trailer jack failure. [emoji45]
Postby Tom&Shelly » Sun Sep 29, 2024 6:40 pm
Yikes! Do you know what brand yours is? We have one that looks just like it.
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby gudmund » Mon Sep 30, 2024 1:56 am
go to Tractor Supply and check out the "Ultimate Tongue Jack". seeing the frame you have in the picture, I am thinking you could use one - there is alot less cranking with one being the crank-shaft tube is an adjustable up/down 'slide tube' that you set/pin before raising it up/down. This also helps being when not in use it can be stored higher up away from the roadway when traveling, = no bottoming when going in/out of driveways thus damaging it. Have been using mine since 2018 and it still works great.
gudmund
Images: 39
