by Ottsville » Wed Apr 02, 2025 7:16 am
General visual inspection of outside, note anything that looks unusual for a deeper look.
Second pass visual inspection - check tires, coupler, propane mount and hoses, any exposed wiring, etc
Check doors(hatch), struts, hinges and latches. Lube anything that needs it, silicon on rubber seals, etc.
Check function of windows, vent
Check exterior lights and brake function
Jack up one side, check for play in wheel, visual brake inspection through backing plate, and with my ez lube hubs add fresh grease. Lower and check lug torque, repeat on other side.
Check tool/emergency kit. Restock anything you might need.
Inside, check spaces for pest intrusion, check screens, lighting, wipe everything down. I pull out all cooking/eating supplies and wash. Restock and go!
