noseoil wrote:How about a slice of 1/2" material to pad out the inner wall faces & make a "lip" which protrudes up past the 1/2" rabbet a bit on the inside? This would help keep any water which leaks past the seal in a small "gutter" and rolling down to the floor, so it can be directed outboard and escape.
I used 1/2" birch plywood to make mine & mounted a strut attachment to this inner face as well.
noseoil wrote:Sorry I didn't get back to you sooner, didn't see the thread again until now. Here's a shot from inside with the 1/2" spacer & an extra piece for the strut mount fastened in place.
Here's the rough-in for that part, being fit to the inside & curve & checked.
