aggie79 wrote:A rule of thumb is for the clearance for the seal/weatherstripping is to be about 1/4 to 2/3 of the thickness of the seal. My "notch" is 1/4". On top of the galley sidewall I added aluminum trim that was 1/16". I also added .040 aluminum on the underside of the hatch skin that overhangs the sidewall. This left a clearance a little less than 3/16" inch. The D-shaped seal I used was 1/4" tall, so when the hatch is closed it "squishes" a little more than 1/16" (or 1/4 if the 1/4" seal height.)
