Hatch gasket
Hatch gasket
Postby fourbtgait » Thu Feb 18, 2016 10:01 pm
Has anyone tried/used this gasket from Trimlock for a rear hatch?
1/4" ply inserts into it negating the need for alum angle trim.
Good, bad review?
fourbtgait
Images: 16
Re: Hatch gasket
Postby Redneck Teepee » Fri Feb 19, 2016 10:09 am
Yes. This is how my rear hatch is trimmed and sealed. So far no issues with leaks, seems to do the job even when I wash/rinse it with a fanning pattern from a spray nozzle on the hose. :thumbsup:
Here's the catalog link
http://www.trimlok.com/prod/Catalog-700_179.aspx
Click on hatch seal
Redneck Teepee
Images: 21
Re: Hatch gasket
Postby fourbtgait » Fri Feb 19, 2016 3:43 pm
Thank you. Yes, I found it in the Trim Loc catalogue. I thought it would provide a nice clean edge instead of the typical bent angle.
Glad to hear it works well for you. Is it very still in compression?
fourbtgait
Images: 16
Re: Hatch gasket
Postby vegask » Fri Feb 19, 2016 3:51 pm
Redneck Teepee wrote:Yes. This is how my rear hatch is trimmed and sealed. So far no issues with leaks, seems to do the job even when I wash/rinse it with a fanning pattern from a spray nozzle on the hose. :thumbsup:
Click on hatch seal
Do you have any pics of how you set that up?
vegask
Re: Hatch gasket
Postby fourbtgait » Mon Mar 07, 2016 9:45 pm
It is easy to set up. I went ahead and ordered it. Closed it flattens to 3/4-7/8" wide. I laminated a rain channel also for it to but against.
It will look clean I think.
fourbtgait
Images: 16
