Built-up Walls For The Lil'Diner
Postby mikeschn » Wed Nov 17, 2004 11:46 am
Sure, someday, when I get it back from Steve!!! :)
P.S. So are you playing any more with your Dinette trailer profile?
Postby Steve Frederick » Sat Nov 27, 2004 10:26 pm
Hello all!
I got a bit more done on the Lil'Diner. I made up a jig and got the wall framing started. I have the curbside framing done, just have to trim with the router. Streetside will get started tommorow.
I updated the Build Journal tonight, more to follow!
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby mikeschn » Sun Nov 28, 2004 6:19 am
Steve the furring is looking good. And I see you have wax paper under the furring, so you're obviously not gluing the furring to "that" piece of plywood in the photo. So what are you driving the screws through? A spare template? :?
Postby JunkMan » Sun Nov 28, 2004 10:15 am
Steve,
Everytime I see a pic of your woodie, I wonder how you got the stripes in the sides. Is that paint, or did you cut a groove into the plywood with a router, then fill it with something?
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby Steve Frederick » Sun Nov 28, 2004 4:18 pm
Jeff,
That's done with a router. I cut 1/4" grooves in the panel, using a pattern. I flipped the pattern, routed again. I filled the grooves with 1/4" strips of Mahagony and Ash.
Cut the grooves..
Fill in the grooves..
I sealed everything in 'glass/epoxy.
Mike,
That's a template. I'll assemble the furring for the twins on it, then use it over and over again, in smaller pieces, as a pattern for other components. A good use for a couple sheets of ply I had laying around! :thumbsup:
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Steve Frederick » Sun Nov 28, 2004 6:46 pm
Here's the framing after a few minutes with the router. The twin curbside wall is on the jig in the foreground. I'll do both streetside walls this week.
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
