Slide out for the Cooler - Assistance
Postby Classic Finn » Sat Jan 20, 2007 10:03 am
Dear Friends
I would like to install a slideout system for our cooler.
Even though the technical specs have nothing to do with the slides but here is our cooler. The Isotherm TB 32
TB 32 comes with injection moulded cabinet and a blow-moulded detachable lid. High-density insulation and an integrated evaporator, ensures food and drink are kept cooler for longer. An internal light is mounted. The TB 32 also incorporates an AC/DC converter as standard and its multi function electronic thermostat has an ECO function that keeps electrical consumption to a minimum. It has recessed hand-grips.
Type TB32
Volume (litres) 32
Dimensions
HxWxD (mm) 380x335x580
Weight (kg) 18
Power
Consumption (Amp)
Average/Max (12 V) 0.7/4.0
Danfoss Compressor Type BD35F
Freezer -10°C 32 or
USA specs - Specifications
TB32 - 8.45 gallons real capacity
Dimensions - WxHxD: 22.84 X 14.96 X 13.2 Inches
Danfoss Compressor BD35F
Voltage: AC/DC 110-240 V and 12/24 V
It will not fit in the length way.. only side.. and Id like for it to slide out.
the original accessorie is very expensive here ... meaning the slide out system... and its in my opinion no better than the slide brackets available at hardware stores...
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby halfdome, Danny » Sat Jan 20, 2007 11:41 am
Heikki, Since you want to make your own slide out for the cooler just make a tray from 1/2" Baltic Birch Plywood. I would make the tray 3" tall and use 1/2" for a flush bottom. Make a separate front to match your cabinet fronts for a nice finished look. Your drawer guides should be a minimum of 100# load and full extensions. American slides come in even lengths. If you will have left over space behind the cooler then make a partition to hold the cooler and use the extra area for other storage. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Classic Finn » Sat Jan 20, 2007 12:06 pm
Thank You Danny
That is most impressive of a slide out you have there... :thumbsup:
Ok so back to makin dust... :twisted:
Best regards Heikki
Classic Finn
Images: 146
Postby Classic Finn » Sat Jan 20, 2007 12:50 pm
Got just enough height under the countertop with a lil room to spare...as the countertop isnt permanently installed.. :thumbsup:
Classic Finn
Classic Finn
Images: 146
Postby grant whipp » Sat Jan 20, 2007 1:02 pm
Hey there, Heikki!
Don't forget that thing needs air around it to work properly, and a source for fresh air wouldn't be a bad idea. Have you thought of an air vent opning in the floor or something of that nature?
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby Classic Finn » Sat Jan 20, 2007 1:04 pm
Grant Whipp wrote:Hey there, Heikki!
CHEERS!
Grant
Hi Grant
Ive thought about small vents of stainless on the sides... as for yachts or boats with the cabin..but the air movement is a good piece of advice..
Thank You
Heikki
Classic Finn
Images: 146
Postby halfdome, Danny » Sat Jan 20, 2007 1:36 pm
CHEERS!
Grant
Good call Grant. :thumbsup: Heikki, I just noticed your cooler has a side vent. I would notch that 3" tall tray down 2 1/2" to the tray bottom where the cooler vent would be so it doesn't restrict air flow.
:) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Classic Finn » Sat Jan 20, 2007 2:02 pm
CHEERS!
Grant
:) Danny
:lol: :lol: I also caught that on the slide tray... as I was looking at the cooler here.. it does also have a compressor which again has a fan with it...Danfoss Compressor.
Heikki ;)
Classic Finn
Images: 146
