1st Time Builder Skin/Roofing Question
Postby tinksdad » Thu Jun 26, 2008 6:20 pm
grant whipp wrote:Most people avoid using these FRP panels for exterior use, as they have no UV protection built in and will deteriorate in short order. Some folks have painted it with decent results and have greatly extended the life of the panel. If you decide to buy it and paint it as you've stated, make sure the paint you use has the highest available UV protectant rating.
Back to the drawing board!! I love this site. You guys are keeping me from making some expensive mistakes. Since I'm painting the roof any ways, it looks like the double 1/8" is the way to go..... if I can find it. At the one local lumber yard (not big box store) I checked with so far, the man I talked to looked at me like I had suddenly sprouted a third eye in the middle of my forehead when I asked about Baltic Birch.
tinksdad
Images: 155
Postby mikeschn » Thu Jun 26, 2008 6:23 pm
Also check out the original "Buford T" Home Depot Panel build...
http://tnttt.com/album_cat.php?cat_id=5
Postby Boodro » Thu Jun 26, 2008 9:49 pm
Tinksdad , I have FRP on the roof of the Dew Drop Inn. It has been over 2 years now & I have NO problems with it. It is still shiny after a wash & the dirt does not stain it. It currently is sitting under a cherry tree & I don't worry about it. It sat outside all winter , & has been outside all this spring & summer too. It has NO yellowing or brittleness to it either. I did have it on the sides but changed over to a woodie look last fall. I like it alot!!! It is very easy to work with & bend . It takes FRP glue very well too. It stays cool to the touch in the sun also. Good luck with your build!!! :thumbsup: :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Users browsing this forum: Bing [Bot] and 8 guests
