Philip
tinksdad wrote:How hard is it to cut a 1/16" groove all the way around the door? What actually holds it in place... just compression on the ridges on the flange?
halfdome, Danny wrote:I wouldn't use it. "T" molding is used on cheap institutional cabinets. I have a roll of it in white from a job I did years ago and won't recommend it to anyone. With it affixed just at the 1/16" groove there is no way to protect the wood from moisture unless you goop up everything and that could be a mess and it won't lay flat. It also has a crown to it and can reduce the gap between your door and teardrop. Just my opinion.
Danny
bdosborn wrote:Got a link to the moulding? Looks kind of interesting.
Endo wrote:bdosborn wrote:Got a link to the moulding? Looks kind of interesting.
http://www.rockler.com/product.cfm?page ... okietest=1
Creamcracker wrote:halfdome, Danny wrote:I wouldn't use it. "T" molding is used on cheap institutional cabinets. I have a roll of it in white from a job I did years ago and won't recommend it to anyone. With it affixed just at the 1/16" groove there is no way to protect the wood from moisture unless you goop up everything and that could be a mess and it won't lay flat. It also has a crown to it and can reduce the gap between your door and teardrop. Just my opinion.
Danny
plastic molding is just that - plastic molding even when used on "cheap institutional cabinets" or on "expensive arcade video games" it's still plastic molding -- I sealed the edges and as to the crown -- that's exactly why I used it!
Philip
halfdome, Danny wrote:Creamcracker wrote:halfdome, Danny wrote:I wouldn't use it. "T" molding is used on cheap institutional cabinets. I have a roll of it in white from a job I did years ago and won't recommend it to anyone. With it affixed just at the 1/16" groove there is no way to protect the wood from moisture unless you goop up everything and that could be a mess and it won't lay flat. It also has a crown to it and can reduce the gap between your door and teardrop. Just my opinion.
Danny
Philip
I've built hundreds of doors with the stuff. Over time it will break loose from the groove. Do a test and pull the "T" molding from one end and find how easy it is. It's meant for interior applications. It's your choice, good luck. Danny
Danny
Philip
