A different type of T-molding
Postby Creamcracker » Tue Sep 02, 2008 10:59 am
just fitted this t-molding on the door -- its from the "arcade video game restoration industry"-- (yes there is such a thing) It gives a nice finish and was very easy to fit after routing out the 1/16th slot. I need to seal the edge of the door yet and then it'll be done.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby Mary K » Tue Sep 02, 2008 11:22 am
Oooo, thats nice. :thinking: Might have to look into that!!
Thanks
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby tinksdad » Tue Sep 02, 2008 6:59 pm
How hard is it to cut a 1/16" groove all the way around the door? What actually holds it in place... just compression on the ridges on the flange?
tinksdad
Images: 155
Postby rainjer » Tue Sep 02, 2008 8:02 pm
tinksdad wrote:How hard is it to cut a 1/16" groove all the way around the door? What actually holds it in place... just compression on the ridges on the flange?
They make a router dit for cutting the groove. You can get the same stuff from a lot of flooring companies. It is sold as countertop edging. Yes, just compression fit.
Jeremy
rainjer
King Koleman
Images: 11
Postby Creamcracker » Tue Sep 02, 2008 9:44 pm
Yes a 1/16th router bit -- I bought it from the company that sold the t molding. I tested cuttinbg on some wood scraps -- it turned out easier than I had expected. The part that goes into the slot has barbs on it that hold it in tightly -- I guess that's compression fit.
Creamcracker
Teardrop Graduate
Images: 142
Postby bdosborn » Tue Sep 02, 2008 9:53 pm
Got a link to the moulding? Looks kind of interesting.
Images: 806
Postby halfdome, Danny » Tue Sep 02, 2008 10:02 pm
I wouldn't use it :no: . "T" molding is used on cheap institutional cabinets. I have a roll of it in white from a job I did years ago and won't recommend it to anyone. With it affixed just at the 1/16" groove there is no way to protect the wood from moisture unless you goop up everything and that could be a mess and it won't lay flat. It also has a crown to it and can reduce the gap between your door and teardrop. Just my opinion. :thinking: Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Creamcracker » Wed Sep 03, 2008 6:26 am
halfdome, Danny wrote:I wouldn't use it :no: . "T" molding is used on cheap institutional cabinets. I have a roll of it in white from a job I did years ago and won't recommend it to anyone. With it affixed just at the 1/16" groove there is no way to protect the wood from moisture unless you goop up everything and that could be a mess and it won't lay flat. It also has a crown to it and can reduce the gap between your door and teardrop. Just my opinion. :thinking: Danny
plastic molding is just that - plastic molding even when used on "cheap institutional cabinets" or on "expensive arcade video games" it's still plastic molding -- I sealed the edges and as to the crown -- that's exactly why I used it!
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby Endo » Wed Sep 03, 2008 6:54 am
bdosborn wrote:Got a link to the moulding? Looks kind of interesting.
http://www.rockler.com/product.cfm?page ... okietest=1
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Creamcracker » Wed Sep 03, 2008 7:08 am
Here's the link to the supplier I used:
http://www.t-molding.com/store/home.php?cat=7
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby halfdome, Danny » Wed Sep 03, 2008 10:55 am
Philip
I've built hundreds of doors with the stuff. Over time it will break loose from the groove. Do a test and pull the "T" molding from one end and find how easy it is. It's meant for interior applications. It's your choice, good luck :thumbsup: . Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Creamcracker » Wed Sep 03, 2008 11:46 am
Philip
I'm going to be "gluing" it into the groove. It does pull out easily as you say with those doors that you mention you built.
Philp
Creamcracker
Teardrop Graduate
Images: 142
Postby Hoosier Greg » Wed Sep 03, 2008 11:54 am
Philip
I agree and all that I have seen over the years had a gap where the two ends joined together.I am sure it did not leave the manufacturer with a 1/4" gap..
Greg.
Hoosier Greg
Postby bdosborn » Wed Sep 03, 2008 10:34 pm
Hmmm, I thought it might make a nice table edging but I think I'll keep looking for something else.
Images: 806
