How do you folks make wood putty?
Postby Marck » Thu Jul 07, 2005 11:25 am
I've been making it using titebond 2 and sawdust, but wanted other options.
also been using Bondo, but want to use more wood less bondo.
You want to build WHAT?????
40 isn't middle aged....
IT'S YOUTH PART II
Marck
Images: 64
Postby Arne » Thu Jul 07, 2005 11:40 am
epoxy and wood dust (not saw dust) or micro balloons..... very tough stuff and does not shrink much.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby SteveH » Thu Jul 07, 2005 11:44 am
I use the epoxy method too. Much better and stronger than the titebond. I use saw dust, but it requires a lot of sanding.
SteveH
SteveH
Images: 42
Postby Arne » Thu Jul 07, 2005 11:53 am
I get wood dust from model shops.... fyi...
I have some around from my r/c model building....
I also use bondo, or auto body filler where I need more and it will be covered by paint or some other coating....
Arne
Mr. Subject Line
Images: 96
Postby An Ol Timer » Thu Jul 07, 2005 12:03 pm
My tear is a woody, so at the beginning of the project, I took several different shades of wood scraps. Then I used my 10"-96 tooth carbide Plywood blade which makes very fine dust and I made a number of cuts in each shade of wood. I saved this sawdust in separate containers and it is used separately or mixed depending on the shade of the wood being filled. I use it with an epoxy mix. Not my idea, it came from an oldtime cabinet worker down the road from me.
An Ol Timer
Postby webbedouin » Thu Jul 14, 2005 11:52 am
Was wondering what type/brand of epoxy to use and what porportion of sawdust to expoxy to use???
webbedouin
Postby SteveH » Thu Jul 14, 2005 12:28 pm
I also do radio control models, so the glue that I use comes from the LHS, 30 minute cure stuff. Mix the glue like you normally would, and them add wood dust to it and mix until it gets the consistancy of putty.
SteveH
SteveH
Images: 42
Postby Arne » Thu Jul 14, 2005 12:43 pm
yes, kind of like a peanut butter consistency.... spreadable, but not too thin, don't want it to sag.
Arne
Mr. Subject Line
Images: 96
Postby Chris C » Thu Jul 14, 2005 1:13 pm
Another thing to remember: You want to mix it as thick as you can and still apply it..............otherwise it will be too dark and will not stain or dye properly.
Chris :D
Chris C
Postby shil » Mon Jul 18, 2005 3:35 pm
Save the dust collected in your orbital sander and mix it with epoxy. It matches whatever it is that you're sanding.
shil
