Changing paint color on Aluminum Window
Postby John6012 » Tue Jul 26, 2005 7:09 am
I bought a picture window for the front of my TD that I'm planing on building and it has a white frame. I have another one for the side and it has a black frame. I want to wrap it with silver colored aluminum and would like all windows to be the same color. Has anyone painted this type of aluminum before? I even thought of white aluminum for the roof and silver for the sides due to the withe window frame in front...maybe it'd be cooler in the hoter weather? :worship:
John6012
Postby DestinDave » Tue Jul 26, 2005 7:26 am
I've painted a lot of aluminum window trim rings and aluminum outboards and outdrives. The metal needs to be sanded smoth, wiped down with acetone or denatured alcohol and then primed. I usually use a spray can of zinc chromate for the primer because it's quick and dries very fast. Then you can spray the finish color. Build up a couple coats with light scuffing in between coats to get a nice slick finish. Dave
Reality? What a concept!
Building "The Salty Tear" - a photo log of the project.
http://www.bluezenphoto.com/p979644357
DestinDave
Postby ALAN GEDDES » Tue Jul 26, 2005 10:00 am
I like to media blast them and then spray with clear.
Alan
ALAN GEDDES
Images: 34
Postby John6012 » Thu Jul 28, 2005 8:01 am
Thanks for the replies. I'm going to atempt painting the window. I'd rather have one solid color (silver) on the trailer. Can I use spray pain in a can? After I prepare the metal frame?
John6012
Postby DestinDave » Thu Jul 28, 2005 7:11 pm
Sure can... to make sure it's a high quality exterior paint I'd suggest using a Rust-Oleum product or go to an automotive paint supply store and see if they have a spray in the color you want. Remember to clean and prime the aluminum well first - a good prep is the key to a nice finish.
DestinDave
Postby John6012 » Fri Jul 29, 2005 8:34 pm
Great and thanks! The only problem I'll have now is the white vinyl holding the window in the frame.
John6012
