Need a hatch fix.
Need a hatch fix.
Postby montanablue » Sun Oct 02, 2005 7:56 pm
This is my first post. I am seeking wisedom from those who have traveled before me.
My hatch is done and the right side looks good. My problem is that the leftside does not follow the contour as it did when I made the frame. Everything matches until 8" from the bottom. I will try to post some pictures as soon as I learn how to post. http://tnttt.com/album_ ... ic_id=3190
http://tnttt.com/album_ ... ic_id=3189
Is it possible to bend it back into shape by using eyelette screws, wire and turn buckles. i would attach eyelettes at the top left and bottom left. I figure I could keep turning the turnbuckle until it comes back into shape. There is one thing I did that makes me think that it will not work. I sandwiched aluminum between the plywood. It is pretty stiff
What do the Kings of the Tears say?
Thanks,
Rick[/img]
montanablue
Images: 30
Postby randy chesnutt » Sun Oct 02, 2005 8:46 pm
rick, .i have traveled before. it,s hard to say what to do with out photo. with alum. between the wood will make it tuff to work if not impossible. just back track yourself and see what started the problem and work from there. how far is off? after you have looked it over give us some more information hang in there. welcome to the forum
randy chesnutt
Images: 65
Postby doug hodder » Sun Oct 02, 2005 9:03 pm
Montana....it is tough without a photo....when I built my hatch, I skinned the interior first, in 1/4 inch birch...I had enough springback that the exterior curve changed..I figured out how to take care of that in the future...I had to build up the members and then shape to fit the sides of the trailer...you may have a similar problem...it's not that tough to fix..and how far off are you compared to the profile you want? ... a picture would be helpful....I'm sure someone here on the forum has had a similar issue and you will be able to find a fix....Doug
Postby Denny Unfried » Sun Oct 02, 2005 9:43 pm
Have you applied an inside skin yet. If not, you might try to pull the left side into shape with your turnbuckle and even a little tighter than you want the finished curve. Then, install your inside skin using plenty of screws & finish washers into the outside ribs. When the turnbuclke is released the new skin will help to hold the new shape.
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby Gage » Sun Oct 02, 2005 10:55 pm
You might check for interferance with the counter or somthing else that might be holding your hatch out and not letting it close. Also why did you put alum sheeting in between the ply sheeting? Did I read that wrong?
Have a good day, hope you get it fix'd.
8)
Image Image Image
Gage
Images: 28
Pictures of my hatch are in my gallery.
Postby montanablue » Mon Oct 03, 2005 6:55 pm
I have posted the pictures of my right and leftside of my hatch in my personal gallery. As you can see the leftside is off at the bottom.
Answers to questions?
Yes, I have skinned the inside of Hatch.
Also, I did use aluminum to strenghten the framing.
Now that you have the pictures, what are your suggestions?
I look forward to hearing what you have to say.
Montanablue "Rick"
montanablue
Images: 30
Postby Gage » Mon Oct 03, 2005 7:35 pm
Studying your pictures, it looks like maybe your side trim is off. Did you build your hatch in your tear and then prelocate your hinge while the hatch was in place? How did the hatch fit before you attached the hinge or did you notice?
Another question. The alum that you sandwiched. Is it sheet or extru. I don't understand what your saying when you said you "sandwiched alum between the ply". If it's sht, that may be the cause by wanting to spring out straight.
Have a good day.
8)
Image Image Image
Gage
Images: 28
Postby goldcoop » Mon Oct 03, 2005 7:43 pm
Montana-
The eyebolt/cable/turnbuckle thing is exactly what I had to do on the Ctear's 6' hatch when things got out of control!
One eye at top, one at bottom, cable in between with the turnbuckle in the middle.
You should probably get at least a 1/4" x 2" lag eyebolt of GOOD quality.
Predrill thru the ply/alum sandwitch with a 3/16" bit and drive your eyes.
Try this and as you snug up the TB make sure you are getting the desired results w/o bending your eyes; you may end up having to go larger/longer!
I ended up using S/S 5/16 x 5 lags in mine!
Now that this arrangement has been on for the past 6 months or so the hatch has gained "memory" of the shape and I could remove the whole mess, but the wife & I have found the cables too useful as mini clothes lines!
Cheers,
Coop,
goldcoop
Images: 32
Postby montanablue » Mon Oct 03, 2005 7:50 pm
goldcoop wrote:Montana-
Cheers,
Coop,
Coop,
Thanks for the reply. Do I understand that this would be something that I would have to leave on for some time? I ask this because the wire would hit the counter which I have already installed in the galley.
What are your thoughts?
Rick
montanablue
Images: 30
Postby montanablue » Mon Oct 03, 2005 7:57 pm
Gage wrote:Studying your pictures, it looks like maybe your side trim is off. Did you build your hatch in your tear and then prelocate your hinge while the hatch was in place? How did the hatch fit before you attached the hinge or did you notice?
Have a good day.
8)
Gage,
Thanks for the comments. I did not install the trim on the galley walls when making framing. When I covered the hatch with 1/8 luan on top, it fit well. I covered with aluminum and it still looked OK. In fact, Chip came over to look at it.
The aluminum is from sheet. What I don't understand is why one side is perfect and the other is off. Any ideas?
Thanks,
Rick
montanablue
Images: 30
Postby goldcoop » Mon Oct 03, 2005 8:05 pm
Rick-
Sorry, I forgot to mention this arrangement was made from the outside edge of my hatch, which is mostly exposed multi layers of ply.
I'll take some pics and post to my personal gallery in the A.M. light...
Cheers,
Coop
goldcoop
Images: 32
Postby Will Smith » Wed Oct 05, 2005 9:23 am
I think you had a latch, the latch would hold it down just fine
Benefit mankind, use your screen saver for something useful. More information here:
http://www.worldcommunitygrid.org/
Will Smith
Postby Chip » Wed Oct 05, 2005 9:45 am
Rick,, are you gonna be working on the trailer this evening,,, give me a shout or post a pm here,, got an idea that might work,, but would have a relook at the rear hatch how it seals to the floor
chipper
54"x9'4" tear
4'x8' tear
Chip
Images: 49
