roof edge molding - sealant question
Postby Dick » Thu Oct 08, 2009 7:13 pm
Getting ready to add the roof edge molding in next couple of days. Is there a recommended method such as using butyl tape under the trim or using a silicone - or something else?
Thanks in advance for the advice
Dick
Images: 11
Postby wannabefree » Thu Oct 08, 2009 8:21 pm
A lot of people use silicone. I hate the stuff and use something called Lexel. It's water clear, cleans up with paint thinner, and is paintable. Silicone isn't clear, is a bear to clean up, and won't take paint.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby madjack » Thu Oct 08, 2009 9:29 pm
I used hi-tek stuff on the first one...on the second, I used standard RV butyl tape...pulled it over the edges and then applied the trim...inexpensive, will stay pliable/hold a seal for a long time and is removable if needed.........
madjack 8)
Postby Steve_Cox » Fri Oct 09, 2009 7:23 am
butyl tape :thumbsup:
silicone sealant - just a nasty mess destined to fail :lol:
If you have any plywood end grain exposed, it is a good idea seal it with several coats of epoxy.
Steve_Cox
Images: 196
Re: roof edge molding - sealant question
Postby Classic Finn » Fri Oct 09, 2009 1:39 pm
Dick wrote:Getting ready to add the roof edge molding in next couple of days. Is there a recommended method such as using butyl tape under the trim or using a silicone - or something else?
Hello Kansas City and Greetings from the Country of Finland.
Butyl Tape is also used on our tear. However with a small exception or slight mod. Here I used RV Molding with a 2 in 1 Rubber Seal with Butyl Tape on the bottom side. No leaks at all. Notice the thin layer of plastic. That is peeled off as you set the seal/butyl tape down under the moulding.
Our style of RV Moulding below.
And Rubber Seal/ Butyl Tape in 1 conformed to the above moulding.
Best regards
Classic Finn and Family :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby planovet » Fri Oct 09, 2009 2:30 pm
madjack wrote:I used standard RV butyl tape...pulled it over the edges and then applied the trim...inexpensive, will stay pliable/hold a seal for a long time and is removable if needed......
+1 That's what I did :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
thanks for all your advice
Postby Dick » Sat Oct 10, 2009 7:26 am
Appreciate all the advice - decided to use the butyl tape for sealing - easier than the messy silicone stuff. Used the butyl tape for the hurricane hatch hinge and the result was a "good looking" install and no mess. On the contrary I used silicone to seal around the vent fan as per mfg instructions and my caulking skills looks like #$@%. Oh well, it's on the roof where most people can't see it up close and as long as it doesn't leak it will be fine.
Again thanks to all!![/code]
Dick
Images: 11
Users browsing this forum: IndigoIrish and 7 guests
