Flooring???
Flooring???
Postby Kelleyaynn » Fri Feb 26, 2010 4:47 pm
Is there any particular reason to put flooring down in the teardrop? I don't really see the need, except in the galley part, since the entire floor will be covered by the mattress. :thinking:
Kelleyaynn
Postby dwgriff1 » Fri Feb 26, 2010 6:34 pm
I was going to put a hunk of vinyl floor covering on the floor until I realized it would weigh 20 or 30 pounds and that paint is a lot lighter.
Likely no one will see the floor, but you!
But, there are lots who have nice floor coverings under their mattress.
dave
dwgriff1
Postby Gage » Fri Feb 26, 2010 6:51 pm
dwgriff1 wrote:Likely no one will see the floor, but you!
dave
Yep it just gives that finished look. Also it aids in insulation. Think about it. But like that, to each his own.
Image Image Image
Gage
Images: 28
Postby planovet » Fri Feb 26, 2010 7:24 pm
dwgriff1 wrote:I was going to put a hunk of vinyl floor covering on the floor until I realized it would weigh 20 or 30 pounds and that paint is a lot lighter.
I put 12"x12" vinyl tiles on our floor, and I even went to the trouble of making it into a Swiss flag (go figure). It was cheap and didn't take me long to do.
Who is going to see it? No one but us. But I like it and like Gage said, it gives it a finished look. It also gives a nice smooth surface for the foam mattress to lay on.
ImageMark (& Cindi)
planovet
The Cat Man
Postby john » Fri Feb 26, 2010 8:43 pm
If you plan to sell it, it might be more profitable to sell it with a cheap floor covering than a mattress. Or it may just open you up to keeping your mattress when you do sell it.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby afreegreek » Fri Feb 26, 2010 8:52 pm
I'm going for the slate tile..
afreegreek
Postby dwgriff1 » Fri Feb 26, 2010 11:32 pm
afreegreek wrote:I'm going for the slate tile..
Ya gonna set that with mortar or on wonderboard?
dave
dwgriff1
Postby S. Heisley » Sat Feb 27, 2010 12:47 pm
If you decide not to add flooring material over the deck, you might want to at least put some sort of finish coating on it to prevent water damage.
...One never knows how or when water will work its evil ways! :twisted:
Postby Arne » Sat Feb 27, 2010 3:02 pm
I put a carpet remnant on the floor space I could see with rubber mats for wet shoes....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
